Dashcam hardwire fuse recommendations for a 2022 xl
Oldgaffer
2022 xl
Hi all,
I want to hardwire a VIOFO A119 Min 2, but I am not sure what the best fuses are to tap with the HK4 kit.
Can anyone please give me what is recommended to use?
Thanks,
OG
Sticks
Shawn
St. Louis
Sticks
Shawn
St. Louis
Thanks m8!
I can't use that harness as I have a 2022 xl... no power in the rearview mirror :(
I will check out that other link tho... thanks again!
No Mavericks come with power in the rearview mirror from the factory.
The harness taps into the dome light to provide power for aftermarket accessories like dashcams and auto-dimming mirrors.
Oldgaffer
Oldgaffer
2022 xl
Really! ... I read "somewhere" that trims above XL had powered mirrors and you could tap into them. I did not know about tapping into the overhead lights. Looks very clean, the only negative is no parking mode.
Oldgaffer
Oldgaffer
2022 xl
So many different sources telling me different things.
Can anyone verify they used these?
🟡 Yellow wire (CONSTANT power)
Fuse 21 — 7.5 A
Climate control / E-shifter module
âś” True battery power
âś” Stable, low draw
âś” Proven safe for parking mode
đź”´ Red wire (ACC / ignition-switched)
Fuse 11 — 5 A
Telematics control unit
âś” Ignition-controlled
âś” Clean wake/sleep behavior
âś” No high-load or safety risk
Hot Runr Guy
West Chicago, IL
Fuse 21 — 7.5 A
Fuse 11 — 5 A
As indicated in the linked thread above, I used a micro-3 fuse in position #1-2 for an ACC (switched) source. Nothing else is run off that position. 3 years now, in 3 different Mavericks, no problem.
HRG
