Cold Start Issues
Djhartman712
DJ
New Jersey
2022 Ford Maverick XLT Hybrid
Help needed...its been nice and cold here in Jersey.
Hybrid ran fine on Saturday. Snow came Sunday and when I went to start the truck, all kinds of alerts popped up then battery died. Installed a new battery and truck still dead. Only when connected thru cables to another car does it get power but still wont turn over and still loaded with alerts.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
Disconnect and reconnect negative lead on battery and try again. Recommend a battery check and a using a battery tender, upgrade to AGM if a new battery is warranted and you haven't already. Cold doesn't harm batteries, but it will reveal when they're weak.
Bigberm
Randy
canada
2024 Maverick XLT
bull19541
Bruce
Oakview
2025 lariat
loose grounds in cold weather. my time in Alaska the engine grounds would end up loose from the cold and engines would not start.
also a thread showing buss under fuse box shows corrosion. he took volt reading at the battery (correct)then at fuse box that volt reading was low.
J
NY /VT
26 Maverick on order
Amazing what a little cold will do to contacts. In a Manhattan apartment I had a leak where the toilet tank attaches to the supply line. Cause... cold tap water.
22MY - did you have recall regarding the 12V battery strap?
Was it done?
Djhartman712
DJ
New Jersey
Here's the latest on what is happening with my Maverick...and NONE of us would have guessed this one.
Apparently squirrels climbed into the engine bay on a frigid cold night and had a little chewing party. They chewed thru every wire they could get their little teeth on AND some of the firewall as well.
OleFordGuy
Oh wow that’s gonna take a hit on the billfold
OleFordGuy
