Center MPH on the 2023 Lariat Instrument Console
letsrock23
Orlando, FL
2023 Ford Maverick Lariat
Does anyone know how to center the MPH on the 2023 Lariat instrument console? My dad has the XLT and it is center, but mine is down on the right corner.
Rolmav
Kansas City
2025 Maverick
Do you got a picture of the dashscreen you're on? You would need to be on the Calm Screen for it to be fully in the center.
Stimpy433
Chad
Iowa
2022 Mavrick
Calm screen
jsus
2022 Ford Escape Hybrid AWD
Tblast503
2024 Ford Maverick, 2020 Subaru Outback, 2018 Subaru WRX
Only if you knowingly want to turn off the Lane Keeping System, which is a safety feature. Only if it's too much of a nuisance should one consider turning it off.
https://www.ford.com/technology/driver-assist-technology/lane-keeping-system/
Correct.
https://www.ford.com/support/vehicle/maverick/2023/owner-manuals/
LANE KEEPING SYSTEM LIMITATIONS
The lane keeping system only operates when the vehicle speed is greater than 40 mph (64 km/h).
The system works when the camera can detect at least one lane marking or the edge of the road.
The lane keeping system may not correctly operate in any of the following conditions:
  • The lane keeping system does not detect at least one lane marking.
  • You switch the turn signal on.
  • You apply direct steering, accelerate fast or brake hard.
  • The vehicle speed is less than 40 mph (64 km/h).
  • The anti-lock brake, stability control or traction control system activates.
  • The lane is too narrow.
  • Something is obscuring the camera or it is unable to detect the lane markings due to environment, traffic or vehicle conditions.
The lane keeping system may not correct lane positioning in any of the following conditions:
  • High winds.
  • Uneven road surfaces.
  • Heavy or uneven loads.
  • Incorrect tire pressure.
SWITCHING THE LANE KEEPING SYSTEM ON AND OFF
Ford Maverick Center MPH on the 2023 Lariat Instrument Console {filename}
To activate the system, press the button on the turn signal lever.
To deactivate the system, press the button again.
Note: When switching the system on or off a message appears in the information and entertainment display to show the status.
Note: The system stores the on or off setting until manually changed, unless it detects a MyKey™. If the system detects a MyKey™, it defaults to the last setting for that MyKey™.
Note: If the system detects a MyKey™, pressing the button does not affect the on or off status of the system.You can only change the mode and intensity settings.
SWITCHING THE LANE KEEPING SYSTEM MODE
The lane keeping system has different settings that you can view or adjust using the information display.
The system stores the last known selection for each of these settings. You do not need to readjust your settings each time you switch on the system.
To change the lane keeping system mode, use the instrument cluster display:
  1. Select Settings.
  1. Select Driver Assistance.
  1. Select Lane-Keeping System.
  1. Select Mode.
  1. Select a mode.
Note: The system remembers the last setting when you start your vehicle. If the system detects a MyKey™, it defaults to the last setting for that MyKey™.
WHAT IS ALERT MODE
Alert mode vibrates the steering wheel when it detects an unintended lane departure.
ADJUSTING THE STEERING WHEEL VIBRATION INTENSITY
To change the steering wheel vibration intensity, use the instrument cluster display:
  1. Select Settings.
  1. Select Intensity.
  1. Select an intensity setting.
Mabcim
Rochester, NY
I don’t like that first either, but quickly got used to it being off center.
