Can't turn off or disable lane centering
Dave Leebrick
98 Ranger, 24 Maverick
Lane centering is usually only available when Adaptive Cruise Control is turned on. But, I got into my 2024 Lariat and somehow the alarm started sounding and emergency blinkers turned on. A little embarrassing to say the least, but then I noticed lane centering was turned on (dash light illuminated). Tried turning it off using the steering wheel button; the light would turn off (visible but no longer green), but lane centering was still active. Turned vehicle on and off several times, but lane centering is still enabled. When I turn on Adaptive Cruise Control, lane centering works normally, but I just can't disable/turn it off .
I can ignore the little dash icon easily enough, but the lane indicators remain on the small display, which pushes the current MPH indicator to the lower right of the display and in smaller font.
Got any ideas, short of powering the whole truck down?
Lane centering only works with adaptive cruise. Lane keep assist works only when it's turned on, button on end of turn signal stalk. Maybe that's what you accidentally turned on?
He said the switch on stalk turn light off but the lane centering dash screen turns light off but does not drop the dash screen to the format it would be before land centering was activated.
Cigargoyle
Denver NC
2022 Maverick FX4K
Does the icon have a steering wheel in the middle or a car? If a car, the lane keep assist is turned on (icon won't be green). If a steering wheel (and icon is green), then it is indeed lane centering, which shouldn't be if adaptive cruise is not on.
dc73pdsgt
Tucson, AZ
go into menu on the center display and go to driver assistance. scroll through till you find lane centering and uncheck the boxes.
sundog
Indianapolis
Ford C-Max
Seems like we have a bit to unpack here:
  • The alarm going off just happened and is completely unrelated to cruise control or the issue reported by OP
  • The button in the stalk is for lane keep assist, which doesn't require ACC.
  • For lane centering, there is a button on the left cluster of the steering wheel along with the other cruise control buttons, with a steering wheel in between two lines, to toggle on/off.
Maybe OP just needs to disable it after they turn in the ACC?
Related discussion with pics: https://www.mavericktruckclub.com/forum/threads/lane-keep-only-works-with-cruise-on.16665/
