Bronco sport to maverick wheel question.
Cadillacman
Jerry
Earth
Ford maverick xl
I have an xl with 4k tow. Maverick Gvrw is about 2800. 2800 divide by 2 is 1400 pounds, for the maverick. Bronco sport gvrw is about 2400 divide by 2 and bronco sport gvrw is 1200. Maverick and bronco sport both come stock with continental tires h rated at 1850 pounds. Aftermarket wheels I have seen are between 1400 and 1800 pound load. I cannot find load ratings for ford oem wheels. I know the maverick stock wheels have been tested load wise for that truck.. The bronco sport oem wheel I found is an 17 by 7, 63.4 bore, 37.5 offset, 5 spoke silver alloy Model number m1pc1007f1a. Only question I have could Ford have designed the Bronco sport with a lesser grade wheel that doesn’t meet load specs for Maverick, even though it fits. Please advise. Thoughts. Thx
SLJ
Elbridge New York
There might be a load rating stamped on the back of each wheel.
Cadillacman
Jerry
Earth
Ford maverick xl
What does it look like, I haven’t bought the wheels yet
Hot Runr Guy
West Chicago, IL
The lowest BS tire I find comes with a 102 load index (1874#), I can't imagine that Ford would under-size the wheel spec below what the tires are rated.
HRG
SLJ
Elbridge New York
My Maverick rims (4K) say DOT-E on the inside. Which if this is the load range ??? that would be E weight capacity, which per DOT is 1,520 lbs. I have 18" Bronco Sport wheels on my Mav but would have to remove one to check.
Cadillacman
Jerry
Earth
Ford maverick xl
would you go remove it and see………just kidding
Hot Runr Guy
West Chicago, IL
@SLJ, where did you find that DOT chart?
HRG
SLJ
Elbridge New York
I just did a search for "DOT E range" and found a DOT paper listing ranges/pressures/weights/etc. for tires/wheels along with a whole bunch of manufacturers tables also.
