Broken front grill at 1000 miles
LC48
Johnson County Texas
Insurance looks like to me ~ rock or some road debris got ya.
I would rinse that area from time to time until you get a proper repair part installed, it is open to the elements from below so no harm no foul. If you were to pull the factory cold air inlet duct you will find there are actually two sets of openings for cold air but the factory inlet actually blocks the drivers side off, seems weird, but that drivers side inlet will let you see the back of that upper grill section.
Was running a clay bar on mine today and found a ding on the hood leading edge right above your puncture, a perfect little divot......good old DFW highways
jtpc2021
Oklahoma
cosmetic damage from object impact.
it is closed for aerodynamics, but having it open like the lower grille won’t rust out you truck or anything.
Ktobaygo
Kyle
Eastern Connecticut
Ford Maverick XLT
Worst case I take a dremel and cut out the rest of the plastic that is left and do the same to the other side. 😪
Just a little high for fog lights but someone is gonna come up with a reason to "Dremel" them bye-bye!
Hot Runr Guy
West Chicago, IL
OK, being that I've spent my entire career (40+ Years) in the injection molded plastics industry, I've got to ask, just how jagged or rough are the edges of the hole? This almost looks like a molding defect, what would be called a "short shot". If the right side is smooth and rounded-over, it didn't break off, it was never properly molded.
HRG
Ford Maverick Broken front grill at 1000 miles FD90BDEA-3C88-4FF3-9C01-D071B7A71D8E
Ktobaygo
Kyle
Eastern Connecticut
Ford Maverick XLT
HRG
Ford Maverick Broken front grill at 1000 miles B883E871-1523-4A42-8B5C-01653EB6E0C0
Here’s a better picture. Looks worse the more I look at it.
  • Wow
Reactions: NDL
GaMaverick
Rich
Georgia
Mustang
First post here !Not sure how this has happened.. or what to do now. Losing sleep knowing it is winter and all the salt and sand will be building up inside of here. Very disappointed on this quality of material. Looking for some advice … should I call my dealership? Local body shop ? Will follow up with a better picture. Thanks everyone.
Ouch, imagine if that rock would’ve hit your windshield 😬
jtpc2021
Oklahoma
I wish Ford had just matched the top grille with the lower. The fake top area looks so cheap on the XLT.
But again, I realize having it closed off is better for efficiency, however they could have left it open and had active grille shutters behind it like my Ram.
(and I am aware the Maverick has shutters at the very lower opening apparently, though not mentioned on Ford’s stats on the site)
