APIM Nav upgrade, no GPS tracking?
dalola
Retired
SE Ohio 🇺🇸
Just swapped out my std Lariat APIM for a Nav enabled unit, everything works except the GPS tracking. I get the GPS symbol in the red circle with a line through it, similar to what happens when you lose satellite communication due to heavy forest, etc..
Any thoughts what might be wrong? Hoping it's a just setting that I'm missing...
Waiting hear back from the vendor Monday also.
1buddyc
Buddy
San Antonio, Texas
2021 Lincoln Nautilus 2025 Eruption Green Maverick 2006 Chevy SSR
Would you mind letting us know who your Vendor was? And, did you find a YouTube or any other Video that showed the process for doing this swap?
Thanks in advance for for your reply..
dalola
dalola
Retired
SE Ohio 🇺🇸
I'm working with breeves002 (do a search), a well known source in this field.
He has the unit back, to confirm/reflash the firmware, as something was not right. He's been great to work with so far, even covering return shipping. Hopefully it's just a programming issue, and I'll have it back shortly. He's currently out of Sync3 gen 4 units.
I don't know of any videos, but I can give you a quick run-down of the process.
Remove the HVAC panel (all clips) starting at the top corners and work your way down. Unplug the 2 HVAC couplers, and set the panel aside.
Unclip the 2 wire harness stays at each side of the opening, and remove the foam insulator.
Unplug the 5 couplers in the control unit, and remove the 4 screws holding it in, and wiggle it out and set aside.
Unscrew the 3 screws on the APIM bracket. I bent the bracket arms in flat to aid removal, and access the 4 couplers on top of the unit. When couplers are unplugged, remove the unit/bracket assy, then separate the bracket from the unit with 3 screws.
Reverse to install the new APIM.
First time I did it, took me about an hour figuring everything out & being very careful. Second time about 15 minutes. Looking forward to the third time. (NOT)
1buddyc
Buddy
San Antonio, Texas
Thanks, much appreciated..
