bluesteel
Jerry
Bergland, MI (U.P.)
2022 Maverick Lariat
With no aftermarket rear seat "delete" kits apparently available (yet), I took it upon myself with a sheet of 3/4" plywood.
There's another thread out there from someone who used a 4'X2' sheet and just bolted it down into the seatbelt floor anchors. My solution took considerably longer because I wanted to fill a few more inches of space in each dimension. I ended up buying a 4'X4' high-quality 3/4" sheet and cutting out a 27"X40" section that I bolted in. Then I added a hinged smaller section (11" wide - I forget the length dimension offhand, but it's shorter in order to be able to clear the seatback and swing up). This allows access to (part of) one of the underseat storage areas. This configuration took up just about all of the usable width inside of the rear doors (51").
Due to a lot of little issues, this took a lot longer than it should have, but I'm pretty happy with how it turned out. Only slight regret is that I'd thought about finishing the plywood somehow for those times it gets wet. Instead I settled for attaching adhesive neoprene (which I already had) along some of the edges - I need to buy some more to finish it. I play to leave most of the platform covered with a foam mat as shown.
There is one problem with bolting in a pre-cut sheet and just being done with it: Although there is a mostly solid, plastic-covered metal frame around the front and back of the underseat area, the back middle of it (the crossmember) is slightly higher than everything else. So once I got the plywood fitted, I ended up sticking on small, thinner pieces of wood - shims, if you will - in several spots to make sure the sheet was level and had no noticeable curvature or "give." So it's not just supported by the higher center piece and wobbly on either side of it.
Tips:
  • The seatbelt anchor bolts are M10 1.5 pitch. I purchased new ones with 50mm length since the original bolts were not long enough for the 3/4" plywood.
  • The small holes behind the seatbelt bolt holes are for screws that protrude from the floor; I wanted them to be able to pass through the board.
  • I also attached adhesive neoprene to all contact points, especially weight-bearing points, in the underseat storage/support area.
  • I left the seatbelts attached behind the seat. It appeared it might be a challenge to remove at least the driver's side belt. Also, removing the wiring to the seatbelt sensors would have triggered a fault warning every time I start the truck. I found a Forscan fix for this that supposedly worked on a Ranger, but I decided it wasn't worth the experimentation. Maybe later.
The main reason I did this was for the dog (I want her as low in the vehicle as possible for safety and minimal distraction). But it will be much better for cargo capacity even when she's not there. I have absolutely no need for a rear seat 99.5% of the time.
Maybe eventually a good solution will be developed to put a cover in place of the seatback as well, but for now I'm not concerned about it. Everything looks good and I'll probably cover the seatback with a sheet for protection.
Ford Maverick Another rear seat removal - tips & photos IMG_2169
Ford Maverick Another rear seat removal - tips & photos IMG_2167
Ford Maverick Another rear seat removal - tips & photos IMG_2172
Ford Maverick Another rear seat removal - tips & photos IMG_2168
Ford Maverick Another rear seat removal - tips & photos IMG_2173
Ford Maverick Another rear seat removal - tips & photos IMG_2160
TomMav
Minnesota 55060
02 Mazda Miata
Thank you for this information. A question did you happen to take pictures or document on how you removed the bottom rear seat? Which bolts need to be removed?
Thanks in advance.
P.S. I am still waiting for my 22 Mav 444 days. Can't find a transport for the last 45 miles to my dealer.
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
Thanks in advance.
Sorry, I didn't document with photos, but here are the highlights as I remember:
  • Remove blue trim plate from each seat hinge - there is a single screw holding each one on with a round plastic cover clipped over it. This slowed me down for awhile when I couldn't figure out how to remove the cover. Eventually I looked at it from behind at the right angle and discovered each one was held on with three small clips. Still hard to get it off without breaking any of the clips, though.
  • Remove two black torx bolts from each hinge that hold on the lower part of the seat. At first I thought it would be possible to remove the part of the hinge itself that the lower part of the seat was connected to. But the hinge is all really one mechanism, so I couldn't easily remove any of it, which is why you still can see it protruding at the base of the seatback in the photos.
  • Turn and pull out a small metal nub that holds a cable on to each end of the lower part of the seat near the hinge.
Good luck with your delivery - that must be frustrating! I didn't have to wait long so decided to frustrate myself with this instead!
TpaTruck
Guest
Tips:
Interesting.. My question is... Why? Seriously, don't understand why you would want to take the seats out? If it's to have a flat hard surface, why not just put the plywood over the seats? Maybe I'm missing something...
Stevo
Stevo
Chicago
Lots
Yep...you are missing something. If you don't use the back seats, it is common to maximize the space by removing the rear seats. Did it on a chevy Colorado. Was amazing.
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Not just why; but hell why!! Not enough storage in the truck bed? Get a different truck!!
hungliketictacs
Austin
Maverick EcoBoost FWD
I personally love it! Would love to see even the back rest deleted to make full use of space, I was thinking about a crate for the pup for saftey reasons as well.
skinnyboy
Andy
Ontario, Canada
Since it makes it possible to conveniently and cost effectively have a more flexible storage space for items not suited for rolling around in the bed in the elements. Not sure a different truck would be better in this regard, and almost definitely not as fuel efficient.
Cheers.
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Cheers.
LOL' I'm planning on putting dividers in the bed and use the back seat mostly for my dogs. I have a seat protector, door panel covers, and a net barrier. Hope your plan works out.
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
More power to you. If you think the choices are to 1) keep a vehicle as it is, or 2) buy a different model, I guess there’s no need for the mods forums!
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
It's always good to keep your options open. LOL
taylor_
Taylor
Denver
Maverick Lariat Ecoboost AWD
It's your truck and do what you will with it, but this seems like a lot of effort for what ends up being only marginally better at best than just laying some wood over the seats. Or just using a seat cover and putting things on that.
TpaTruck
Guest
You got me there, I didn't read all of the posts... Gave up after the instructions started I just saw the pics. I forgot people like to turn this into a work truck.
skinnyboy
Andy
Ontario, Canada
Thanks, working out well so far. Hope your mods work out too!
