Anybody experiencing a loud and noisy compressor when air conditioner is on while in park?
Here's mineAlso note that the condenser is a three phase motor driven. If you are more than 2°F from the set temp it will run faster to increase BTU output. Speed of condenser will also increase as fan speed is increased and will make more noise. If you have AC on automatic the condenser and fan speed will vary much more and make less noise as temp of cabin approaches the set temperature.
Also: when in auto set the fan to the max speed you want auto to use. Then if you want more fan just put it on max cool and AC will turn every thing on full blast until you put it back on automatic and the fan and condenser will drop to their appropriate speed depending on temperature difference from set temp.
Fix what? It's working as designed. It's a scroll compressor.QUOTE="Glen Baker LLC, post: 1178306, member: 34289"]
YES
Anyone have a fix or solution?
