Adjustable/Easily removable bed divider.
bik77
bik77
Massachusetts
2011 Lexus RX350 150Km
Ahh I see that it is made of wood. The paint made me think it was a piece of aluminum. I was thinking if it went out above and below the cargo rail it would be solid enough to keep it near vertical. Like a 3 pronged guide instead of the single one in this picture. Really as I think about it if you just made that thicker/wider (maybe 3 layers thick)just like you have it, it wouldn't be able to tilt off the vertical.
It is a good idea, never thought of this :)
rclee
Rob
Dayton Ohio
That is pretty slick! I wonder if you could put some kind of small roller(s) in the grooves on the bed floor instaead of the L brackets?
Redbirdfan94
Chicago, IL
2023 Maverick Carbonite Grey
Material used is 1/2 plywood and 1x3 wood on the top. 3/4 plywood would be better, but I did not have piece big enough. Top piece is painted with aluminum spray and clear coated, divider itself pained with bedliner spay. L-brackets on the bottom are not drilled - they just helping divider to stay vertically.
Thanks.
Svtguy
Ian
Cambridge ON
2023 Ford Maverick XL 24 Tremor on order
Thinking about buying a Ford OEM Bed divider -not cheap to buy
My question is it worth the money ,from owners ?
Svtguy
Ian
Cambridge ON
Would you do it all over again ? Cheers
bik77
bik77
Massachusetts
Absolutely. But I would use 3/4 plywood instead of 1/2. Divider is so convenient and I still have all the mounting points.
Vettereddie
MD
2023 Maverick XLT
This is a great concept with the spring loaded locking pins! Gives me ideas to try with some aluminum rail to match the factory cargo management and do a quick spray-in coating for the board to go with the bed.
