Adjust electrical cut off time (after the ignition switched off) on wire in rear bed cubby box?
Gpp
Gil
Sanford nc
2022 ford maverick
I understand the wire in the cubby box to connect to electrical accessories has a timer to
Cut the power off after 15 minutes after the ignition switch is cut off. .by any chance is it adjustable?
OleFordGuy
??? Not aware of a factory wire being in the cubby hole in the dash next to radio
Gpp
Gil
Sanford nc
2022 ford maverick
Cubby box in the rear corner box in the bed.i changed the title of post a little😎
OleFordGuy
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
You might be able to do it with ForScan, but I'm not sure which setting it would be. There are a couple of threads on here that discuss using ForScan to change settings. You might want to see if it was discussed there.
