Adding an additional lower dash power point?
Potatomafia
Eastern New Mexico
2023 Ford Maverick XLT Hybrid
Has anyone added another 12v socket to the lower dash? I need another socket to plug in my dash cam and it seems like there is a lot of wasted space around the existing 12v socket. Adding another socket means I can have a plain 12v socket and the stock one which has my USB-A/USB-C phone charger in it.
How does the lower dash panel come out?
Ford Maverick Adding an additional lower dash power point? -ONLY-178-Miles-4K-Tow-Pack-Well-Equipped-LIKE-NEW
Johnkn
MD
You can add a splitter into that 12v port or do it the correct way and not run wires visible in the cabin.
bgn
WA
Look at other installation threads on here for dash cams. They've tapped into the cabin fuse box in the passenger footwell. Much cleaner, imo.
OXHB619
Clayton
XL EB 2.0
I use the USB A for wireless Carplay, and the USB C to USB A for my Dashcam. Charging is slow from those ports anyway, I recommend a better charger for the 12v port to dedicate to charging.
Ainope 12v Charger https://a.co/d/eYyc0tH
90* USB A Adapter 2 pack https://a.co/d/1P32fa5
90* USB C to A Adapter is no longer available, you will have to search for one
Wireless Carplay ( out of stock but worked well in my XL and now Lariat) https://a.co/d/8tkoyzn
Ford Maverick Adding an additional lower dash power point? IMG_2183
Braderick
Brad
High Point, NC
Bolt EV, RAV4 Prime, KИ EV6
Plenty of room to install a new port. You can tap or add a fuse, as others have mentioned.
Pull front of panel downward, then pull towards you. Recommend a panel tool. It makes a lot of noise, but do what you're comfortable with.
Ford Maverick Adding an additional lower dash power point? IMG_6988
Potatomafia
Potatomafia
Eastern New Mexico
This is exactly what I was looking for. I'll wire it to a ignition switched fuse in the cabin fuse box. Thanks!
Braderick
Brad
High Point, NC
I changed it up a little...needed a few more ports. The ON/OFF switch is nice to have.
Ford Maverick Adding an additional lower dash power point? IMG_0566
Ford Maverick Adding an additional lower dash power point? IMG_0568
