Can you share the forscan version you have?OK, I finished hardwiring all the slices.
The engineers at Forscan turned around a beta version for me that lets me calibrate CCM and ABS. I was able to calibrate the CCM sensor, so I think I'm good to go on that front. I used an AsBuilt file from a LariatLux and entered my hex VIN.
I have the programming finished as far as I can tell, but I'm still getting a couple codes:
ABS U2101
IPMA U2101
IPMA Signal plausability (forgot to write down the code)
I tried resetting the ABS configuration back to stock and the code persists, which leads me to believe it's an interaction with another module that is causing the code.
Does anyone know if the ACC and non-ACC models have different IPMAs?
EDIT: After thinking about it some more, I feel like I would have been unable to calibrate the CC-M sensor if I had the wrong IPMA. There must be some other incompatible setting that's causing these issues.
