AC power behind rear seat?
dumbcomputers
The Earth
2025 Maverick Lariat Hybrid
Does anyone know I can get 10amp ACC power behind the rear seat on a Lariat?
Ranko Kohime
Ranko
2025 Maverick XLT
To clarify, you’re looking for 12v, switched?
Simplest way is a fuse tap taken off under the glovebox with the wire routed under the door sills.
If constant 12v is fine, just tap the battery that is under the center-right rear seat (hybrid)
dumbcomputers
dumbcomputers
The Earth
Yes, 12v switched. I realize I can always get it from the fusebox, I was looking for an easier option.
BlueSpec1
Gene
ACC Switched 12V doesn't go to rear seat area.
Fuse info from a 25 Maverick Lariat
Ford Maverick AC power behind rear seat? 1769011405032-ui
Ford Maverick AC power behind rear seat? 1769011301018-24
Quest
If you want a 20A switched circuit you could use 1 of the box power point circuits.
They run down each side & can be accessed behind the rear seat or rear foot scuff panels
dumbcomputers
dumbcomputers
The Earth
Any pics of their location/harness?
Quest
Im in the process of doing a video about tapping into these circuits
Heres a few screen shots of where I tapped in .
I found tapping in at these locations was easier as the harness isn't wrapped under the harness boxing
The right side is a 14GA yellow & green wire switched & 20A fused at the Battery Junction box.
Ford Maverick AC power behind rear seat? PP2
Ford Maverick AC power behind rear seat? PP1
dumbcomputers
dumbcomputers
The Earth
Awesome! Let us know when you have the video up!
