FrankM
Frank
2023 Maverick Hybrid XLT
Hello, I've done some recent work to my Maverick.
after installing the Elevate bed rails (along with my Bakflip hard Tri-fold tonneau cover, I added the Elevate Bed Rack.
Installation was simple and straight forward. I did lower the crossbars by one notch to make it more inline with my aftermarket roof rack, but still not perfect - but ok for now.
Keep in mind the Elevate cross bars are thick - like over 4"! None of my existing clamp on roof rack accessories fit. I ended up order some t-slot kayak saddles off of eBay and they work fine.
Previously I was using the hitch bed extender from Harbor Freight. Works great, easy to load and unload the kayaks, but I did miss not having a rear view because my tailgate (and rear view camera) was pointing downward.
Now I'll have a couple different options to haul around stuff ..: and I picked up 2 more kayaks lol.
Ford Maverick Kayaks on Elevate Bed Racks IMG_0573
Ford Maverick Kayaks on Elevate Bed Racks BA2C6997-21B7-4B28-AC77-F4FE2DCD19DB
Ford Maverick Kayaks on Elevate Bed Racks 424174ED-C673-4098-8135-2C6A5F178B95
Ford Maverick Kayaks on Elevate Bed Racks IMG_0600
Ford Maverick Kayaks on Elevate Bed Racks IMG_0572
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
This is a perfect example of how the Elevate makes room for all your gear. The roof rack/ Elevate duo is a brilliant setup, especially for kayaks. We get asked a lot about this specific setup, and your build really showcases exactly how it works and looks.
The cross bars are a bit chonky and that equates to better stability for your attachments. We've recently introduced a line up of Elevate attachments like a kayak carrier, bike carrier, and cargo baskets that work perfectly with the cross bars, as well.
Love to see it in action! Thanks for sharing! 🤩
lm126027
Larry
Central MA
2024 EB
I thought about adding a bed rack, but just decided to stay with the roof racks for my Kayak. If mine was as long as yours, may be a different story.
Ford Maverick Kayaks on Elevate Bed Racks 20250707_083416
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Also an Elevate Rack owner, it works well for me. Only downside is the inability to put the last panel of a trifold cover against the back window.
For my Kayak I went with a Thule T-track mount, since I also have a rack mounted bike rack and cradles would not work.
Ford Maverick Kayaks on Elevate Bed Racks IMG_0943
bsenecal
vermont
, 2022 Ford Bronco, 1968 Ford Mustang, 2022 American Coach American Dream 39RK
That’s what our plan is , since I bought the 3 flip bedcover without rails to add the racks in the back.
Our kayaks are short so I figured I would save $1000.
Cancunbadlands
Cancun
Cancun
Nice set up
TheSEARCH
Dan
ford
I used Elevate rails BUT the rear uprights I made myself. This way I load from the rear and use the front Yakima cross bar as my kayaks are long.
Ford Maverick Kayaks on Elevate Bed Racks IMG_20240325_165956968_HDR
FrankM
FrankM
Frank
Hmmm....I have the Bakflip G2 and am able to fold the last panel up against the rear window.
Did you get those cradles from an ebay store? If so, can you share the link
I picked these up....
JOYTUTUS T-Slot Kayak Roof Rack... https://www.amazon.com/dp/B0GCHJ3KKV?ref=ppx_pop_mob_ap_share
But you'll need to file down the metal tab. It's too wide to fit in the t-slot.
icegradner
I have an MX4, different design I guess. It won't clear the supports for the cross bars with the rack in the lower of the two positions, which I use. Looks like yours are in the high position, my rack may be a older version, it only has two positions that I'm aware of.
Ford Maverick Kayaks on Elevate Bed Racks IMG_0956
Shark6047
Ed
Broward County, Florida
2026 Maverick, XLT
What type of Kayak holder are you using or is that for something else?
Hot Runr Guy
West Chicago, IL
Just a thought, are the crossbars long enough to allow you to rotate the upper supports 180 degrees, so there is more clearance with the smaller radius toward the inside?
Ford Maverick Kayaks on Elevate Bed Racks 1783208301258-ga
HRG
icegradner
HRG
It still wouldn't clear the bottom of the crossbar in the low position. Not a big deal, when the trifold fails (and it will), I'll get a roll up. It's not a big deal for how I use the truck anyway. When I need more space the bed cover simply comes off completely.
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
Hi there! The new models do have 3 positions now. Unfortunately the only hard covers that clear are the roll ups like the X4s for the previous gen Elevate rack.
