Big_T
T
2022 Maverick XL Hybrid
Hefty little suckers.....
Goose..you there?
Kentucky
Maverick XLT
Cubican
Pedro
Ridgeline, viper, c8
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
Stock steelies weigh 27.2 lbs on my scale (steel wheels only).
For comparison purposes, the Alutec Grip alloy wheels I put on my RAV4 are 22 lbs each for size 17x7.5.
TacoHolder
Phoenix AZ
Not Mav
Actually pretty light for 17" steelies.
My old Subaru had 16x6.5 steelies that weigh 29 lbs each, which I replaced with OEM (Enkei) alloys at 16 lbs each. Shaving 52 lbs of unsprung & rotating weight makes a big difference. The 16x7 steelies on my current Tacoma weigh 30 lbs each.
JsnMrd
2016 Honda Civic Touring
So the aluminum wheels on the XLT is lighter so better fuel economy?
710-oil-614
Cal
2025 Hybrid AWD Lariat
not necessarily, what is the weight of the OEM XLT alloy wheel?
I would have to assume that the XLT alloy wheel is at least marginally lighter (2-4 lbs) but if it has a wider wheel you get into contact/patch surface area and also tire weight. I would assume the steelies and alloys are similar.
However - it doesn't mean you couldn't find better efficiency in a very lightweight set of 17" alloys with a lighter weight all or 3 season tire (Ie not an off road heavy tread tire).
villageidiot
Southern California
many many in the past, none currently
given that steel is 3x heavier than aluminum as a base material, one would assume a steel wheel is heavier.
but
the oem alloy wheels are a LOT thicker than the steel wheels.
that’s not to say they’re heavier, but until one gets weighed, it’s sheer speculation.
710-oil-614
Cal
but
Of course - which is why I said that I would assume the aluminum would be some weight less than the steelie. But like you pointed out - how a wheel is constructed can play a massive role as well.
villageidiot
Southern California
The best aluminum wheel I have ever seen is from Mercedes, 81-84 240d with a hubcap. The wheel looks like a regular ol steel wheel. BUT, it’s aluminum, and weighs 9lbs
