24 Lariat Keyless entry (not keypad). Unlock only driver's door?
Mr Pmzrq
Glenn
2024 Maverick Lariat AWD
The keyless entry (put your hand in the handle) works great except that it always unlocks all four doors. Using the remote, I get the option of single-click to unlock only driver's, or double-click for all. I don't seem to be able to find that option for the keyless entry. My wife will be driving this occasionally and need o make sure she can get in without unlocking all of the doors. The '22-'23 version apparently has an option under the vehicle settings to make this change. Can't find the same thing on my '24. Has anyone found this?
Thanks in advance.
Jtitzer56
Jeff
Evansville, IN
Lariat AWD EcoBoost
Try pressing and holding the lock and unlock buttons for a few seconds, the lights should flash and it'll switch to driver priority unlock.
adam110102
Adam
MA
2025 Maverick Lariat Hybrid AWD
There's also an option in the Settings (center console) to control the locking behavior. I set mine exactly as you want from there.
Mr Pmzrq
Glenn
Can you tell me where this setting is? I've looked through the system and can't find it anywhere.
Thank you.
Thank you.
I do not have 24 but on my 2022 on the remote push both the lock and unlock buttons and hold them both down for FOUR SECONDS to turn the driver only lock/unlock on or off (reversing the current driver only or all doors action)
Toddman45
Todd
St. Louis, MO
The settings are in your IPC you have to go under vehicle and change it in the lock settings either one press for drivers door or one press for all doors.
