2025 - Morimoto X3B LED third brake light
Aleks
Aleks
West Coast
I really like the look of the morimoto led brake light, and found a deal on ebay for $128, and finally got around to installing it today.
I did it a bit unorthodox though as I didnt want to go fishing through the headliner so I just cut off the wires of both the stock wiring and the end of the morimoto led harness and soldered them together, added waterproof heatshrink and wrapped it in cloth harness tape, bingo bango ... bobs your brothers sister. The leer tonneau cover made a nice project desk!
Ford Maverick 2025 - Morimoto X3B LED third brake light 1
Ford Maverick 2025 - Morimoto X3B LED third brake light 2
Ford Maverick 2025 - Morimoto X3B LED third brake light 3
Ford Maverick 2025 - Morimoto X3B LED third brake light 4
Ford Maverick 2025 - Morimoto X3B LED third brake light 6
Ford Maverick 2025 - Morimoto X3B LED third brake light 5
Ford Maverick 2025 - Morimoto X3B LED third brake light 7
a quick video
Jroberts302s
Josh
Nashville, Tn
2023 maverick,2012,fusion, 2014 focus,2003 cobra
Nice job!! My truck is white also.
I got one on my 24 XL 2.0 eb
I fished mine through took about 20 mins total I interior clip tools
Bradley
Bradley
Tennessee
2017 F150 King Ranch, Lincoln GT, 1969 Mercury Cougar, 2025 Maverick Lariat
a quick video
Very nice and clear photo's. And a well done job. I like the look of it as well. My Mav is also "desert sand". Does the middle clear LED stay on all the time or is it just for back up and the red on the sides for brake? Also could you put a link in for the exact Brand model that this is? Thank you sir.
Aleks
Aleks
Aleks
West Coast
Thanks!
Mine is space white, but desert sand is an awesome color too!
The white led (cargo light) comes on when you unlock the truck, and goes off once you put it in drive. There is also a button to manually turn it on or off to the left of the light switch rotary dial.
https://www.morimotohid.com/Ford-Maverick-22-Morimoto-X3B-LED-Brake-Light?quantity=1
When searching you want to look for this part#
X3B LED Third Brake Light: Ford F150-SD-Ranger (2015+ w/o Camera / Clear Lens)
Originally I bought this one
https://www.ebay.com/itm/226700471909
I was going to seal the camera hole with a plastic plug or something from Home Depot, but then later found the non-camera version (out of stock now, but was $127.50 when I bought the last one) from the same seller and swapped it, so if you have some diy prowess, don't mind the look of a gap between the white cargo light, then $80 is a killer deal.
Bradley
Bradley
Tennessee
Thanks!
Got it. Thank you again.
Aleks
Aleks
Aleks
West Coast
Did you use your own plug as well?
Kind of, I used the plug off the adapter harness that came with the led light and sacrificed it. The connector for the factory light is under the headliner and I didn't feel like digging around for it, so I just cut it off close to the factory light and soldered a connector from the morimoto harness directly to the factory wires.
