2025 Maverick backup lights too dim / weak
Frenchy
Bert
Taylorsville Utah
20205 Maverik Hybrid AWD 4K town, read
Any 3156 will work, but you will need to remove the side tabs. A Dremel with a sanding drum makes very short work of it.
I use these. They have great heat management, a lifetime warranty and are made by OSRAM in Italy: https://www.amazon.com/dp/B01CKQP5CO?ref=ppx_yo2ov_dt_b_fed_asin_title
I tried 3156 and 3157, they do not work for me .
The bulb 'tongue" is too thin and too narrow. Any idea.
I cannot find anywhere a list of light bulbs used on the 2025 Maverick.
Help please.
Tbone289
MO
Help please.
That's strange. The Sylvania/OSRAM 3156 and 3157 work perfectly with the tabs ground off, like they were made for it. I had no reason to believe those codes wouldn't work for other brands, and from what I understand the 2025 taillights are no different than earlier years. Can you take a picture of the LED modules you're trying to fit and post it? If you can, take a picture of the original bulbs as well.
The bulb codes are listed in your owner's manual. You can use the codes in the manual to cross-reference here:
https://en.wikipedia.org/wiki/List_of_automotive_light_bulb_types
Frenchy
Bert
Taylorsville Utah
I looked in the manual but I was not able to find the list. I shall look again.
Thank you
cclark
Curtis
Virginia
2020 Escape, 2023 Maverick XLT, CG, Eco, 4K
Thank you
It's on page 363 of your manual..wt21w. Good luck.
Frenchy
Bert
Taylorsville Utah
