2024 Maverick hybrid has a defective axle
Jerry1054
Jerry
2024 Maverick lariat
So, after about 20k I noticed outside wear on the right rear tire only. Went to dealer for 20k oil change and checkup. While there I asked them to check the rear alignment and align if necessary. Service advisor come back and says the toe is not correct on the right rear tire, but there is no adjustment or way to align the rear tires. So, I get a new rear axle under warranty. Any body else have this problem?
bajesus8
Olathe, KS
2022 Lariat Hybrid Lux
-He might have a '25 AWD Hybrid
-Might be talking about the front axle
-He might have an AWD Ecoboost
Havent heard of a failed twist beam though.
Alot of us early hybrid owners have had 'Front' Axles replaced under warranty around this mileage so im assuming he means front.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Says in his profile he has a 24 Lariat Hybrid
Regarding the twist beam, it could have been a manufacturing fault and it's been bad since day 1, rather than a failure. A failing front axle wouldn't cause abnormal rear tire wear, best as I can guess.
Chops
Lobo
There is no rear axle on a 24 hybrid
Well then, that was a quick warranty repair. Maybe replaced the Johnson Rod too.
Ok, time to go take a drive…
LSchicago
Lloyd
IL
No half shafts, but it does have a rear twist beam axle. Looks like it twisted to much.
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
I don't think just because the twist beam doesn't carry any driven parts, it cannot be called an axle. Do old pickup trucks that had solid front ends (take a look at a 50's F100) not have what is considered an axle? All Ford cars until 1949 had solid front axles with transverse leaf springs and no driven parts.
icegradner
Edit, okay some quick searching and yes you are right on the money, another name for a twist beam is a "torsion-beam axle".
notfast
Los Angeles CA
That'd be correct. Torsion beam axles are basically what-you-see-is-what-you-get. They are inexpensive to manufacture and take up minimal space under the vehicle, so they are common on entry-level and/or compact vehicles where costs and space are at a premium. But as you found out, if anything is out of whack, the only solution is to replace the entire thing.
I'm a bit surprised that Ford decided it was worthwhile to go with different rear suspension systems depending on drive type. My first-gen Ford Edge was FWD but it was more like an AWD with the RWD system omitted. It even used the same rear wheel bearing assemblies as the AWD, with holes for the CV axles just open to the elements.
