17” vs 18” Rims
thallman1125
Forney, TX
Mazda 3
Forgive me as I’m not very knowledgeable when it comes to picking out the right size rims. I usually just go to Discount Tire and ask which ones fit.
I ordered a Lariat with FX4. The tires and rims coming in are 17”. I saw that the bolt pattern is 5x108 and the rim is 17x7. Would I assume that the 18” would have the same bolt pattern and the rim is 18x8?
Also, anyone happen to know the largest size tire that one could get without any cutting? I believe I saw a 265/60R18 around here.
SgtLip
Donald
Disney World
@thallman1125
WELCOME to the Forum.
Lots of answers here.
Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size
thallman1125
thallman1125
Forney, TX
Mazda 3
Autonomous
PNW
2021 Dodge Promaster 3500, Icky 2015 Outback
17" vs. 18" is not an issue. Concern yourself with wheel offset, rim width, tire width and diameter.
Atisko
Branford ct
Nissan rogue
Correct I saw the 265/60 R 18 had slight rub when turned an extreme position. It would be important to know his rim size.So there’s a good chance you can go one size taller if you don’t have a heavy tread/off-road pattern &or do a 1 inch left on the front.
