12V bed connection?
Zackmix2020
Zack
Los Angeles
2022 ford maverick 2.0
I have a 12 plug in my bed… does anyone know if theirs something that’s plug in play for these things? Or do you have to cut the wires and make your own connection? Is their a name to this plug so I can find some accessories for it?
BILLNOROVILLE
NorCal
prius, Hybrid XLT, Honda 1100Rebel, 2) Hawk 650NT
My XLT came with a short maybe 18 inch two wire with a plug at one end in a clear bag in the glove box. You should look around your truck and see if you see such a thing. The end with the plug is supposed to plug into the bed's 12 Volt plug held by the square cap.
Hizzy8122
2020 Ford Maverick
I looked for a matching connector, but couldn't find one. I ended up splicing and soldering.
Ford Maverick 12V bed connection? 20220212_135044
WenzelR
Ray
North East
Porsche Boxster, Ford Escape
I bought the Cllena Power socket Accessory on Amazon. Pulled off compartment door and Drilled out four 1”holes and inserted sockets. Will wire tomorrow. Matches color very well.
Ford Maverick 12V bed connection? 31D9A30B-E226-497F-8C7E-933EC4A31482
Ford Maverick 12V bed connection? B5116A84-C62C-4698-9DC4-F22CA8E8D988
mamrozek
West Bend, WI
2023 XLT EB AWD, FX4, 4K, CP360, SIBL/Cargo Mgmt, Bed Extender, 235/65R17s
I'm installing the same panel and was wondering if you did anything to waterproof the connections on the back of the panel? I noticed evidence of water on mine when I removed the panel and concerned with corrosion...
JesTr
Jesse
Kentucky
2010 Ford Focus SEL
I plan to install similar 12V product. Would love if one of those came with a light. Use heat shrink wire covering. You can also wrap that in electrical tape for more protection.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I did the Leftside, "Driver's" cubby area. There is no "Underside Panel" because of the Muffler located just below. So any "waterproofing" would be a requirement here.
Ford Maverick 12V bed connection? USB_12volt power set
I just did a "USB/12 volt" setup and added "shrink tubing" and siliconed the edges of the spade connectors. After I connected them.
Jerry
mamrozek
West Bend, WI
Jerry
Great idea... Thanks!
mamrozek
West Bend, WI
dls235
Levi
Sacramento, CA
mamrozek
West Bend, WI
Can that 12v wire be split into two separate connectors? With one going to the outlet station and one going to the LED light?
Yes, here's a pic of the final install with a separate push-button switch for the light. Just split the 12v feed before the (2) switches.
Ford Maverick 12V bed connection? 20231022_093405
