12v Auxiliary Power Source (round/cigarette lighter outlet) -- continuous power?
Thanks, I assume it can be adjusted?
I'll check when I return home.....
Still confused how mine changed on its own.
It times out when the selected time span has expired if nothing is drawing power, giving you time to exit vehicle and turn something on in flex bed. Then it will stay on until the 12v so drops to (if I remember correctly) 12.1 volts. If something plugged into it and is on when you turn truck off it stays hit until 12v so drops to trigger point. Not sure if it stays on when truck is in extended accessory mode but expect it to. This is why Manual recommends not leaving something plugged in as it could have an led ready light or even possibly a non air gap switch that has a small phantom draw.
svogt302
NJ
I believe this is correct.... My radar detector announces when it powers off & I tested it the past few days. After about an hour or so I saw it was still on & 3 or 4 times when I opened the door, it shut off immediately when the interior lights went on. I'm guessing the current draw lowered the voltage enough.
I will properly wire it up to a switched circuit in the spring...
Thanks for everyone's help & assistance
NJBob
New Jersey
My Radar detector powers off if the truck does not move for 5 minutes. If I run into the store I have to manually turn on the detector. However after what it seems like an hour it will start up on its own I assume that's because the 12 v shuts off. I don't think the load on the 12v has anything to do with when it turns off. At least until the battery is depleted.
nunucello
Marcello
New York
If I reset my BMS the 12V works in the tailgate after turning off the Maverick. Then it stope working a few days later. Then I reset the BMS and it works again for 1 day.
svogt302
NJ
I believe this is correct.... My radar detector announces when it powers off & I rested it the past few days. After about an hour or so I saw it was still on & 3 or 4 times when I opened the door, it shut off immediately when the interior lights went on. I'm guessing the current draw lowered the voltage enough.
I've reset several times & didn't see any changes.. Yet!
klutch14u
2025 Maverick XL
Some of the GM trucks, the fuse has 2 positions, in say the top and middle position the 12v outlet is constant power, the bottom and middle position is accessory power. Very nice to be able to change it's behavior.
Deweyordeweynot
Dewey
Macomb, MI
My XL hybrid has a setting in forscan. The default is 4500 seconds.
Interesting! Do you recall where this setting is located? I'm thinking of tweaking it to remain on for a solid two hours instead of the default 75 minutes.
We have a powered cooler that will shut itself down if it senses a voltage drop while plugged in, and the plan is to plug it into the 400w plug in the bed while in transit to the campsite. Once there it would powered from the site's electrical post (we're almost-glamping campers: modern campsites only).
EONR24
Swag
United States
2024 Ford Maverick XL
check out my forscan spreadsheet. Its in there
Maverick spreadsheet
Deweyordeweynot
Dewey
Macomb, MI
dldjtad
Bartow, FL
2023 Ford Maverick
Take a look under the blue line in the picture:
Ford Maverick 12v Auxiliary Power Source (round/cigarette lighter outlet) -- continuous power? sdfsd
