12 volt DC outlet
Mark8
Uppaus
1948 F 1
What do I need to buy to hook up to this socket
Ford Maverick 12 volt DC outlet IMG_4254
NJBob
New Jersey
You should have gotten a connector with the truck.
NJBob
New Jersey
Always wonder what Forsd just didn't put in a standard 12V receptacle. Instead of dealing with this pigtail.
NJBob
New Jersey
Mark8
Mark8
Uppaus
1948 F 1
Exactly. I m pushing 70 and lucky I can use my cell phone :ROFLMAO:. I like a finished look and does anyone have a picture with something plugged in there?
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
I had the one with the truck but also bought these from Amazon and they worked great
https://www.amazon.com/gp/product/B001OAB6BW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I just sent a set back to Amazon. Most have small "speaker" wires. They are not the correct gauge for a 20a fused circuit. They were even advertised for the the Maverick FlexBed.
"worked great" is a relative description.
Will they mate with the bed connector. Yes.
Will they light up your LED lights. Yes
Will they handle a 15a inflator/compressor. No
Don806
Don
SE Ohio
Sure thats the right one? Amazon says it does not fit the Mav and it's a speaker connector.
I have one of them installed from the OEM bed light wiring to my new LED's and have had no issues. Still have one left...........the wires seem larger to me than what I have it plugged into, but that could be due to the outer sleeve? I got the link from a post here on the forum........
Clock Doc
Mass
Ford Maverick 2.0 ecoboost, Ford Crown Victoria
Fords concept for this truck is for you to finish out the truck the way you want. Plus the fewer bits and pieces they put in it reduces cost of the truck.
jsus
2022 Ford Escape Hybrid AWD
The whole idea was to provide so much more than just a 12V outlet. It's a truck bed, they wanted you to have the ability to use the wires to hardwire whatever you wanted. One example would be to run some LED light strips - you've got wires right there waiting for you to tap into them. Part of the "Flexbed" marketing - you can make the truck your own, DIY-style. The video even shows installing your own 12V outlet if you wanted to run a compressor.
Don806
Don
SE Ohio
that's a link to what I purchased and have been using
SkeeterB
The Woodlands, TX
I was unhappy with the 12V using the connector. My Viair compressor was useless using that as a source. Cig in dash powered it just fine. Too long a run with too small wires. It does power an LED light.
