110 volt outlet
cabhrp
Harold
League City, Texas
2023 Ford Maverick XL hybrid
Can the 110 volt outlet on the back of the console be used to charge the 12 volt battery while towing?
JetFixxxer
Jason
Massachusetts
2023 Lariat x2, Lux, Co-pilot 360 Assist
A car battery? Or like a 12v Makita battery?
400w is the max it can handle and no more than 15A. If the charger doesn't draw more than that, it's a no go.
Watts = AMPS X VOLTS
AutobahnSHO
Will
S.Carolina
Maverick, Miata
I think that gets turned off when truck is off?...
Even if it stays off, it will be draining juice from the inverter- is that coming from the 12v or the 400v? If it's the 400v, I wouldn't trust it to keep going as it will eventually get too low and shut off.
wax87
Stuart
Dallas South
2004 Avalon
3.6 amps @ 110 Volts
Johnkn
MD
You're asking whether the 110vac outlet which is powered by the truck's inverter which is powered by the truck's battery can be used to charge the truck's battery.
OrCoaster
Dale
Mid Coast Oregon
81 VW Caddy and 96 Ford Ranger
I think the OP question is about charging the battery in the vehicle they are towing. That is how I read it. And to do that I think others suggest just running a 12-volt wire in the loom that goes to the towed vehicle and plugging it in under that hood.
1929
Lake Michigan
Ford Maverick XLT Hybrid
That is not how I read the question.
Hello OP, please provide details on what you are asking?
OrCoaster
Dale
Mid Coast Oregon
The vehicle he is driving has both batteries being charged if it is a hybrid, otherwise just the regular one if ICE. So why would he be asking about charging a battery if it is not in the towed vehicle? That is my take. Implied logic with heavy assumptions added for confusion and misdiagnosis. Works every time.
Ozarkbeard
While the Maverick is towing something?
Or while the Maverick is being towed?
Rlward
Richard
Hanwell, NB Canada
Honda CR-V, Fird Maverick XLT Hybrid
I would just run an extension cord to the towed vehicle and plug in your charger to the cord then the 12 volt battery.
