1 Hour Canoe Rack
DannyUncanny
Maverick XL
Made from an 8 ft 2X6 and a 12 ft 2X4. I purposefully kept the base pretty narrow so I could get it in and out using the slots in the bed. 2X4 verticals are about 37” to match the roof with foam blocks (no rack).
Ford Maverick 1 Hour Canoe Rack B905FED9-189C-4AE8-8B55-CB18ED7BF200
Ford Maverick 1 Hour Canoe Rack FA9E19C8-9E6B-443F-8380-700A084FA8AA
Maverickman74
Shane
Maui HI
Nice. Good simple solution. Just tell me you have something on your roof other than a pool noodle. You need a crossbar up there or your roof will be trashed when you catch that headwind that one day. Also I would use a ratchet strap or 2 to secure it to the front and rear of the bed, at the top of the frame to reduce wobble. It could even be a piece of paracord or whatever one way and a ratchet strap the other way, as long as the connect to the top of the frame separately. Other wise have fun down on the ole river!
DannyUncanny
Maverick XL
I’ve got three 1/2” ratchet straps on there. Two over the top to compress the boat down and one diagonal to the thwarts to keep it from flying forwards if I hit the brakes. No highway driving today so I didn’t bother with anything to keep it from sliding back.
HughdMan
Hugh
Cherokee, NC
Chevy Volt, Ford Maverick
That's a great idea! I have to build something like that to haul a 40' aluminum extension ladder. That would stabilize the thing (20' long when collapsed), or help to. I was going to stick a bike rack in the hitch and under-hood front cargo straps (I sure envy the ones built in on the Bronco). Wish me luck!
TriSamurai
Nick
Chicago
F150
That is great thinking. I only wish you had thought of it earlier, before I ended up buying an extended rack for the hitch.
4-40-Four
Living room
25 Mav
This is the rack I saw a few months ago... I based my version on this
DannyUncanny
Maverick XL
I rejigged it this summer to tilt the verticals inwards so it's a bit stabler.
Ford Maverick 1 Hour Canoe Rack IMG_1320
DannyUncanny
Maverick XL
1 ratchet strap from canoe to the horizontal and 1 ratchet strap over canoe to the tie downs, and one ratchet strap over the roof through the front doorframe.
4-40-Four
Living room
25 Mav
Sounds good! Some people want ratchet down like it's the Titanic up there! That looks like a good system!
Cancunbadlands
Cancun
Cancun
That is great thinking tho
wax87
Stuart
Dallas South
2004 Avalon
Ford Maverick 1 Hour Canoe Rack 1759754503323-j4
I presume this is your accelerometer and or load balance indicator?
