AUsomTiger
AUsomTiger
Sweet Home Alabama
2025 60th Anniversary Mustang GT BB #0073, 2022 Maverick Lariat
Dad
Ummm you mentioned suspension????
Don’t see it on the list up there.
I was going to ask if he lowered it. Confirmed. Thanks.
AUsomTiger
AUsomTiger
Sweet Home Alabama
I bought the Ford Performance lowering springs and dampening kit. So it lowered my truck to the standard height of new Lobo.
metomwhou
Stuttgart, Germany
2021 C8, 2016 HellCat, 2014 Nissan Frontier-V8
Just ordered them
Mind sharing where you ordered your calipers? Also, what about your rotor and pad set-up?
I have a set of the focus rs calipers that FastMaverick was selling but unfortunately he disappeared before completing the required adapter for those so I'm stuck with some expensive paperweights. and As much as I'd like to do this mod for the additional performance coming down from high speeds on the autobahn here in Germany, I can't confirm that these will work with my factory 18's that I plan to use for winter. I'll probably end up just getting some performance rotors and pads in the stock size.
metomwhou
Stuttgart, Germany
2022 Ford Maverick AWD FX4
Fast Wheels FC04 19x8.5 Wheels
255/45R19 Continental ExtremeContact DWS06 Plus Tires
Mustang MachE GT 4-piston Brembo front brakes
I like this set-up a lot!! Did you order your wheels online? If so, can you share the source?
BTW, I have a 2021 C8 HTC! I've done a couple videos with Misha on the Nordeschliefe, here's a link to the first one. You can just search "misha c8" on YT and see the others.....The car is a weapon in the right hands!!
AUsomTiger
AUsomTiger
Sweet Home Alabama
I got the front calipers off a dead 23 Mustang MachE GT from car-parts dot com and bought OEM MachE rotors. My pads were still good so I am using those. I did this upgrade since others had already proven it would work.
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
What about the centering of the caliper onto the disc? I’ve heard you need spacers.
AUsomTiger
AUsomTiger
Sweet Home Alabama
Here's what my installer used:
(X4)12mmIDx24mmODx3mm Stainless
Steel Grade 8.8 Spacer $4.99EA = $19.96
AUsomTiger
AUsomTiger
Sweet Home Alabama
Don’t suppose you know from where?
I don't know where he got them. From what I can tell, it's a standard washer/spacer size so should be easy to find and cheaper.
Panda Motorworks
Diamond Sponsor
O'Fallon MO
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
Thanks al ot for sharing, been drooling with idea of those brembo since Someone posted here, and the lowering kit is the cherry on top.
Awesome setup.
