You use existing wiring.This prompts a question I've had. There is a power adapter cable available for dash cams, basically using a T-connector from the plug on the back of the mirror. However, I checked the mirror in my 2022 XLT Lux and there is no plug there.
So, are these mirror upgrades only applicable to Lariat trim or is there something else people are doing to make these work on XL and XLT trims?
Another install.This prompts a question I've had. There is a power adapter cable available for dash cams, basically using a T-connector from the plug on the back of the mirror. However, I checked the mirror in my 2022 XLT Lux and there is no plug there.
Thanks for those videos. I would have liked to use one of those T-connectors for my dash cam but they aren't compatible with the Maverick wiring from what I can see there.You use existing wiring.
I actually used these. Smaller and better contact IMO. Of course, direct wiring is best if possible.Thanks for those videos. I would have liked to use one of those T-connectors for my dash cam but they aren't compatible with the Maverick wiring from what I can see there.
After an extensive search (dealers, ebay, FB Marketplace, Craig's list, etc.) I couldn't find one. Settled for an expensive Gentex GNTX-1124 Auto-Dimming Gen 4 Model HFCHL4. Works perfectly, however.Is the Kia mirror actually still available? I thought I read it was discontinued or is the part number above a different part number?
