I've only had my XLT AWD / 4k tow / FX4 for a few days and today was my first chance to drive in the snow and use something other than Normal mode. I have just over 200 miles on the Mav.
I was driving a mix of snow-covered (2-3 inches) country roads, gravel and paved. Max speed 50mph. After a few miles of using the Slippery mode, the ABS braking was suddenly on a hair trigger and severely compromised braking. I had one serious scare coming into a curve as the brakes hyperactively (and uselessly) pulsed with barely a touch of the pedal, but thankfully kept it on the road. It was really bad, even at low speeds and then creeping through the final turn as I pulled into my destination. The ABS pulsed so fast and consistently that there was no stopping power, with the slightest pressure on the pedal.
On the way home, I tried several different settings:
When I drove it a second time later in the day handling and braking were very good again. That trip was in Normal mode, as the roads were mostly clear. ABS is only activating when I really stomp on the pedal, as expected, with a moderate, effective pulse rate.
Thoughts? Enough of a concern that I should have it looked at?
I just would attribute it to ABS sensors getting clogged with snow if not for the console message and improved performance after.
- Slippery with traction control off helped a little with the ABS sensitivity but of course made the handling not as good (so the computer allowed some wheel slippage and didn't trigger ABS as quickly?)
- Minor ABS sensitivity in Mud setting, and it ran at really high RPM over 35mph. Is it a setting intended for lower speeds?
- Driving in Normal had minor ABS sensitivity. In the 2-3 inches of fluffy, driven-on snow it handled well with just FWD.
