USB Hub - Ambient Lighting
RAMS
Rob
NJ
2020 Kia Sorento SX & 2007 Infiniti M35x
Started the Maverick Journey with a 22 Maverick Lariat and just replaced it with a 25 Maverick Hybrid Lariat. My question is the USB hub in front doesn’t have ambient lighting anymore. During nighttime you can’t see the port. Is there a way to get Ford to fix this, or get the old port back since it’s the same. Here are some pics of my 22 & 25.
Ford Maverick USB Hub - Ambient Lighting IMG_2186
Ford Maverick USB Hub - Ambient Lighting IMG_2187
Ford Maverick USB Hub - Ambient Lighting IMG_2188
Ford Maverick USB Hub - Ambient Lighting IMG_2333
Ford Maverick USB Hub - Ambient Lighting IMG_2335
inline_five
2023 Hybrid XLT
You could buy the part. It's fairly expensive however.
It clips out easily and there are just two input connectors on it.
Not sure if it's supposed to be backlit or not though.
JacobEleventeen
Jacob
Moline, IL
2025 Maverick Lariat
My 2025 doesn't light up either. My guess is another thing to cut costs.
Toddman45
St. Louis, MO
I installed my own Ambient Lighting in that area.
Ford Maverick USB Hub - Ambient Lighting 20241117_222926
Ford Maverick USB Hub - Ambient Lighting 20241019_191224
Ford Maverick USB Hub - Ambient Lighting 20241117_222735
Ford Maverick USB Hub - Ambient Lighting 20241019_191128
Ford Maverick USB Hub - Ambient Lighting 20241117_222843
oysterville
Oregon
2024 Maverick Lariat
My personal experience is that once I plugged in a 12" cord that I don't much have to fuss with that area any more, so lighting isn't necessary.
RAMS
RAMS
Rob
NJ
Toddman45
St. Louis, MO
Looks great, what product did you use and how was the install project?
Thanks, I used single smd chip leds from superbrightLEDs.com for the cubby, cupholder area and rear of console mounted using hot glue. For the front footwells a 2" led pod mounted to the OEM location with 3m tape.
It's all wired into the 12v plug wires under the front cubby. To turn on and off it uses and wireless remote inline with the 12v wiring. Brightness is also controlled by the remote.
Ford Maverick USB Hub - Ambient Lighting 20241019_172057
Ford Maverick USB Hub - Ambient Lighting 20241019_172033
Ford Maverick USB Hub - Ambient Lighting 20241013_221746
