Upgraded reverse lights with these LED light bulbs
Helloimnormal
Somewhere
Just wanted to show what a big difference the led lights made on my XL last night! I am including the link.
Alla Lighting WT21W LED Bulbs, Super Bright Rear Turn Signal. Back-Up Reveres Lights Bulbs Replacement 12V 6000K Xenon White
Ford Maverick Upgraded reverse lights with these LED light bulbs 20220527_202759
Ford Maverick Upgraded reverse lights with these LED light bulbs IMG_20220528_120153
Ford Maverick Upgraded reverse lights with these LED light bulbs 20220527_202659
Ford Maverick Upgraded reverse lights with these LED light bulbs 20220527_202708
LeersMav
Maximus GP
Orange County, CA
Now time to change out the front and rear turn signals too.
You have two LED type options: Plug-n-play or add resistor ...... when you go to research you will see what I mean. Many owners have changed it using either.
Plug-n-Play: LasFit
Add Resistor: Most if not all other brands (this is to stop hyperflashing)
NoCoolNameDave
Earth
2023 Maverick Tremor
I was wondering if anyone had this brand these they look like they would work better than the Lasfit ones. How have they held up?
Mc_Flier
Area 51 Maverick Hybrid, Street Glide Special
How do they look like they would “work better?” They just plug in. They both just plug in. Unless I’m missing something, the Lasfit are plug-n-play, no additional steps.
NoCoolNameDave
Earth
Helloimnormal
Somewhere
They are doing fine. Cant say better or worse than the Lasfit. But definitely no problems out of them. That being said, I have changed out almost all of my other bulbs with Lasfit
Ford Maverick Upgraded reverse lights with these LED light bulbs 20230118_041000
Ford Maverick Upgraded reverse lights with these LED light bulbs 20230118_040951
NoCoolNameDave
Earth
I probably will change all of mine as they go out but the reverse lights in these trucks is just pitiful. I'm not waiting on that one.
JT Maverick
New Jersey
Seems I don't think the OEM halogen reverse lights were as bad as many do. I sprung for the $25 upgrade (Amazon) and installed Alla LED replacements last week. I'm disappointed that there wasn't a big improvement between the Alla LED's and the OEM halogens., and I'm thinking the halogens weren't really so bad. Besides seeming to get better reviews, I have noticed that the Alla LEDs are only 7 or 8 watts compared to Lasfit's 15W. So I've ordered replacement's from LasFit ($37 after 10% disount). For an extra $12, hopefully I'll see a bigger difference with the 15W LasFit LEDs. I'll be returning the set that is inferior.
Ford Maverick Upgraded reverse lights with these LED light bulbs Maverick Alla LED Reverse Lights
Ford Maverick Upgraded reverse lights with these LED light bulbs Maverick OEM Halogen Reverse Lights
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
I used the full Lasfit kit, and the difference was astounding. Now you can be sure people can't miss your brake lights.
Nw_adventure
Salt Lake city
Lasfit lights up the whole alley we use. Stock wasn't great but wasn't terrible.
JT Maverick
New Jersey
UPDATE/15W Lasfit Backup/Reverse LEDs Brighter Than 8.5W Alla Lighting LEDs: After being far less than astounded by the Alla Lighting backup/reverse LEDs' improved brightness (vs OEM halogen), as planned I replaced the 8.5W Alla Lighting LEDs with the 15W Lasfit backup/reverse LEDs. To me, in the comparison where it matters most (on my display) the 15W Lasfit LEDs clearly are the brighter of the two. I'd still say the OEM halogens were not so bad, but I've returned the Alla Lighting LEDs and I'm keeping the Lasfits. Note: Original images (with tree) are Alla Lighting vs OEM Halogen; Images without tree are Alla Lighting vs Lasfit backup/reverse LEDs.
Ford Maverick Upgraded reverse lights with these LED light bulbs Alla Lighting LEDs
Ford Maverick Upgraded reverse lights with these LED light bulbs Lasfit LEDs
srfdude44
california
kia optima
Just one thing...LED bulbs work at much lower watts than do halogens: a good example is when I replaced the make-up 120V filament bulbs in my wife's bathroom with 6 W LED bulbs, the difference was astounding. The original filament bulbs were 60 watts. Halogens are not nearly as efficient as LEDs.
Brianx
Pennsylvania
'24 Eco Boost XL Cactus Gray, tow bar, Co-Pilot
The Lasfits are rated at 1600 lumens. Anyone know how many with the OEM halogens?
Montana
Can't remember exactly what bulb they are. 3156/3157? It's not much.
In comparison, the Diode Dynamics are only 310 lumens. I'd take LASFITS "up to rating" with a grain of salt.
