Turn Signal Relay location?
Bolo535353
alfred
2022 ford maverick
I got a 2022 maverick xl and for the life of me can’t find turn signal relay , and ideas?
Micheal
Micheal
PNW
2012 Escape Hy, 2014 Escape, 2022 Maverick Lariat
I alos have a 22. Quick google search turned up this:
On a 2022 Ford Maverick, the turn signal relay is integrated within the Body Control Module (BCM), meaning there is no separate, easily accessible turn signal relay component; instead, the turn signal functionality is controlled by the BCM's software.
Key points about the Maverick turn signal relay:
  • No standalone relay: Unlike older vehicles, the Maverick does not have a dedicated turn signal relay that can be replaced individually.
  • BCM control: All turn signal functions are managed by the Body Control Module.
  • Recall concern: There has been a recent recall affecting 2022-2024 Mavericks related to the rear turn signal functionality, where the BCM software may not properly alert the driver if only one rear turn signal bulb is out; this is addressed by updating the BCM software at a Ford dealership.
Bolo535353
Bolo535353
alfred
2022 ford maverick
Micheal so do I have to install resisters for my led to function ? I have inside cab turn signal flashing fast
Resistors or use FORScan to disable bulb outage detection, yes.
