- First Name
- Jim
- Aug 4, 2023
- Woodstock GA
- 2024 Maverick Lariat Blackout
- Engine
- 2.5L Hybrid
I have a 2024 Lariet which I changed all the old type bulbs to LEDs. I used restrictor for left and right side brake and taillights as well as the front turn signals. Everything has been working great with no hyper flash for bout 6 months. Now all of sudden the right turn signal indicates a hyper flash but the actual front and rear lights blink as they should when viewing. Same results when brakes are applied. I haven’t tried to remove and replace the unit under the dash that breaks the circuit which causes the light to blink, nor have I tested the restrictors to see if one is defective.
Also haven’t taken the Mav to the dealer thinking it’s not a factory issue but a modification which they may not work on.
Any ideas and has anyone experienced this issue?
Update: Today I decided to install a dual USB charger into the cigarette lighter under the dash, had one and mouse use extra ports. I was in the process of removing the right taillight assemble and thought...I'll check the right turn signal to see if the signal module is making that hyperflashing sound. Well to my pleasant surprise it was making the normal sound and the right signal is blinking fine. Now is it possible that the cig lighter is somehow connected to the signal wiring or what. This is totally weird.
