TruXedo tonneau roll up cover - feedback / reviews?
Maverick_316
Jerzey
Mav Hybrid
Is it a good thing that the rubber weather strip is real snug against the top of the tailgate to the point you have to tug on the tailgate to open it? My thinking is it makes for a better seal to prevent water from seeping in, but having never owned a truck before I thought I'd ask the community.
Mine does the same. Just installed it. How is yours making out?
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
Funny thing happened. After applying some 303 to the plastic trim on the tailgate, it no longer is an issue. Haven't had a problem since. No leakage either.
Maverick_316
Jerzey
Mav Hybrid
How about up front by the bulkhead meets the rockers?
Maverick_316
Jerzey
Mav Hybrid
I just adjusted mine to be butted up against it. Was getting some water in from the corners from where the rocker meets the bulkhead.
When I close the tailgate it has a much tighter seal now
Are your side rails totally flush with the rocker panel or hangs over a little
Ford Maverick TruXedo tonneau roll up cover - feedback / reviews? PXL_20221202_165644441
Ford Maverick TruXedo tonneau roll up cover - feedback / reviews? PXL_20221202_165652218
PeteSJCA
Pete
San Jose, CA
2025 Maverick Lariat Hybrid AWD Eruption Green
Mine is great and I installed it in less than an hour! Not watertight, but hey it's a truck. It's TruXedo Sentry CT.
Ford Maverick TruXedo tonneau roll up cover - feedback / reviews? PXL_20221018_201243237
Hdang1980
Elk Grove, CA
Maverick_316
Jerzey
Mav Hybrid
Just minor water intrusion at the corners.
How flush is the seal by the hook to the rocker panel? Just adjusted mine to. Be flush in the back and slight over hang toward the cab
Maverick_316
Jerzey
Mav Hybrid
I have Ford-branded TruXport. If properly installed, it fits and seals well.
As some others have explained, the main areas of concern are getting the cover aligned (centered) on the back rail, applying the sealing gasket across the top of the bed (between the SIBL if equipped), and getting the cover installed in the correct fore and aft position. Mine has about an inch between the rear of cab (glass) and the cover.
It fits, seals, and looks great.
Does yours flap at all?
BuddyS
Rich
Volvo XC60 R Design & 2022 Maverick XLT
I had one on my Tacoma. I was pleased with it; it held up well through 8 winters in the mid-atlantic and 2 summers in FL. Was getting toward the end of it's life when I sold the truck a few months ago.
Maverick_316
Jerzey
Mav Hybrid
No. Depending on how taut it is (varies with temperature), it may have some light ripples, but no flap.
Got it.
Yeah I noticed over forty it ripples a little bit.
I made it as taut as possible. Today was warmer then its been and it looked tighter then it was when it was colder.
