Transmission fluid and other fluid intervals for AWD
2022MavRogueFX
Jimmy
Staten Island
2022 Ford Mav XLT
I couldn’t find it but could anyone show me a post of, other than engine oil, what fluids need changing and at what intervals? I have a AWD 2022 eco boost.
Gpp
Gil
Sanford nc
2022 ford maverick
Just dont fall for the flush your brake fluid bs🤨and power steering is electric so for get that.antifreeze every 100,000 miles,oil every 5000 miles but some of us old farts still change oil every 3,000 miles.i am sure other people will soon charm in!
2022MavRogueFX
2022MavRogueFX
Jimmy
Staten Island
2022 Ford Mav XLT
Tell me about the brake fluid thing? I also see trans, antifreeze and ptu fluid
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Nobody mentioned RDU and PTU.
Yes, what about the RDU and PTU? 😉
dalola
Retired
SE Ohio 🇺🇸
If you are keeping your truck for the long haul, I suggest ATF, PTU, & RDU every 30K, and DOT4 LV brake fluid every 2 years. This assumes a driving environment similar to the "severe" schedule for maintenance.
Gpp
Gil
Sanford nc
2022 ford maverick
I,ve been driving since since about 1967 and had alot of cars over the years and never heard of changing brake fluid til about 5 years ago.i still have some of my older cars 60’ to early 80,s and never touched the brake fluid unless it was low.just hard to teach a old man new ways of doing some things😛
Tbone289
Is 5 years ago when you started reading the owner's manual? Brake fluid flush maintenance schedules didn't just start showing up 5 years ago. But clearly if you don't hear about it and you never touch it, that means it shouldn't be done...
2022MavRogueFX
2022MavRogueFX
Jimmy
Staten Island
2022 Ford Mav XLT
The ‘aint broke dont fix it’ era when cars were cars and trucks were trucks
dalola
Retired
SE Ohio 🇺🇸
Internal brake part corrosion is a slow process. Chances are pretty good you may never have a problem. But eventually seals fail, caliper pistons seize, brake lines rust through.....all preventable with regular brake fluid maintenance. And with modern cars & the sensitive ABS modulators, it's more important than ever to keep up with the brake fluid maintenance, especially if you intend to keep your car for a long time, and not do expensive brake repairs.
Meeka
Jay
2024 XLT 2.0 turbo
Sarcasm again or?
Tbone289
If ya got the Turbo, there are two tiny screen type oil filters.
No one is paying attention to them yet.
Not listed in the service intervals but I’ll change mine about 50,000
They can and supposedly have clogged up due to infrequent oil changes and not using full syn.
Burns the turbo up.
dochawk
doc
Las Vegas
Don't forget the blinker fluid!
Every 6,521 miles, whether it needs it or not!
Escapologist
Niagara Region, ON
Opposite way round for me. Older Dot 3 would get real dirty and absorb water, needed it changed out more like every 3 years. When the synthetics came in, that was when I started doing it "on condition" so more like 5-7 years. Anyway, if you drove cars for longer than 2 or 3 years and never checked brake fluid you must be super lucky or live in the middle of nowhere. City driving you'd have totalled a car with spongy brake response. Anyway, been a thing since forever ago, that has become less of a thing with better fluids but still one.
Though if you get all your brake work done at a shop and are hard enough on brakes to need them done every 2 years you probably didn't notice, or the top ups kept the fluid fresh enough.
