Trailer connector
Warren's rvw
Warren
Sierra Vista AZ
2024 Maverick
Fuse that is for brake light on four point connector for a trailer
Hot Runr Guy
West Chicago, IL
On a 4-flat connector, there is no dedicated "brake" circuit, since it uses the same wiring as the right & left turn signals use. Maybe explain further exactly what is happening, and if the truck turn/stop lights are functioning correctly.
HRG
Warren's rvw
Warren
Sierra Vista AZ
2024 Maverick
All lights on truck work fine . The 4 flat connector right and left turn signal work but brake light does not thought maybe there was a fuse in either the fuse box under the hood or by passenger floor board.The book does not give a good fuse discription.
Hot Runr Guy
West Chicago, IL
So the right and left turn signals on the trailer work, but when you press the brake pedal, they don't light up?
If so, you have a weak ground on the trailer, not good enough to handle the load of both trailer brake lights at once.
HRG
