Topic about fitting bigger rims
Rjckey
Rickey
2023 Ford maverick XLT
I don’t think this looks rubber bandy and it also doesn’t stretch the sidewalls. I think this will be a clean look on the maverick especially cause I have color matched white on everything on it.
Ford Maverick Topic about fitting bigger rims IMG_5416
some very good replies. the solution to the high positive offset wheel issue (which I agree with) is simple: spacers. if you have a 20x8 ET30 wheel and you want the full skateboard effect, you go with 2" spacers. if you just want a little poke, 1" or 20mm, something like that.
use this calculator:
https://tiresize.com/wheel-offset-calculator/
23Lariat nailed it, the 265/50-20 has a ton of tires from 'sport truck' all season to all-terrain, even some with 3pmsf rating if this has to be driven somewhere with real winter weather.
Ford Maverick Topic about fitting bigger rims Screenshot 2024-12-03 145951
Rjckey
Rickey
Once I get everything and complete the build I will make a new whole post for everyone who has a Maverick just in case there’s anyone who wants to go the same route.
FischAutoTechGarten
Peter
Looks kind of donk.... You going to Carolina Squat your Maverick too?
Phimosis
Larry
Santa Clarita, CA
I’d like to not have that bulgy sidewall look
Bulgy sidewall look? You mean the “stretched” look?
Ford Maverick Topic about fitting bigger rims IMG_1798
You said you want to run 20x12 wheels. There are ultra wide tires that are spec’d for 20x12’s, but they are also low profile, like the 325/30R20, but that is only 29” diameter.
once you drop back into 31” SUV sized tires, like a 305/50R20, those are spec’d for 20x11” wheels because they start to look stretched.
if I was in your situation, I would buy quantity 1 of the cheapest 20x12 or maybe 20x11 wheel I could find, then mount the cheapest tire I could find on it and use that to test fit your rig, before dropping serious coin, only to find that you can’t make it work.
oysterville
Oregon
2024 Maverick Lariat
He didn’t say anything about going off-roading.
And saying that he wants concave, chrome, “rims” leads me to believe that he is looking for stance, not off-road prowess. Something like this?
Oh it's gonna be one of those. Their truck, their dreams.
Rjckey
Rickey
This doesn’t look bad. I definitely won’t fit what I wanted so inside I’ll go 29s on 20x10 with the 2in lift and adapters, and I have a buddy with a fabrication business and can cut/trim so I don’t rub.
Phimosis
Larry
Santa Clarita, CA
I believe if I add the 2inch lift kit with 31in tires on 20x12 rims with an adapter/spacer to change the lug pattern it will work.
Here ya go, 20” concave wheels, with spacers, on a lifted Maverick.
Ford Maverick Topic about fitting bigger rims IMG_1836
