Tonneau, did you order one?
Hot Runr Guy
West Chicago, IL
So the insulation between the metal panels absorb the water????
Yes, I believe so. I never separated the aluminum skins from the "core", but whatever they used was able to absorb and retain water. Whenever I folded it up against the back window, water would just leak out, but never completely dry out.
HRG
oljackfrost
Minnesota
How does that work? Is there a video? Can you remove the trifold?
You must remove a tri-fold to use the whole bed. That’s why I’m going for the soft roll-up because it is pretty much out of the way and stays with the truck. Both my sons have roll-ups on Ford trucks.
theek
theek
Michael
Ottawa Canada
Honda CR-V, Subaru CrossTrek
https://accessories.ford.com/cover-tonneau-12759.html#2020/Ranger
The sleek, “no profile” design makes this a favorite.This folding bed/tonneau cover mounts flush with the side of the truck bed.
  • Provides 100% access to stake pockets and works with tie-downs, bed rails, bed extenders and bedliners
  • Made from rigid, heavy-duty ¾” thick panels strong enough to hold up to 300 lbs. (evenly distributed)
  • Rugged synthetic hinges and seals provide outstanding weather resistance
  • Lock the cover in full open position with the included prop rods for access to the whole bed without removing the cover
  • Hidden, quick-release latch system automatically locks panels when shut, simply lock the tailgate to secure the bed
oljackfrost
Minnesota
Yes, you can prop it up to access the whole bed. But if you are carrying large or tall items that extend above the bed sides, you’ve got to take it off the truck. Unless Ford has come up with a storage system that doesn’t exist anywhere else in the industry.
Hot Runr Guy
West Chicago, IL
If the tri-fold is up against the back window, why would this keep you from hauling a tall item?
HRG
Ford Maverick Tonneau, did you order one? bakflip propped
oljackfrost
Minnesota
oljackfrost
Minnesota
theek
theek
Michael
Ottawa Canada
In any case the hard folding bed should be in the 50 pounds range no big to remove.
