TIRES FIT MY MAVERICK?
Mav2023
Mavreal
Northern cali
Mav2024
Hi everyone I run to this deal at Walmart will this tire be ok on my maverick I ask Walmart employee he said it’s ok I want to check here before I decide to install on my maverick thank you
Ford Maverick TIRES FIT MY MAVERICK? 28D297C5-EC8C-41B6-A34D-60F37D2DBE4D
Ford Maverick TIRES FIT MY MAVERICK? 92EAB51C-F973-4724-82F5-3ABCAA3C76E8
imboden013
West Memphis AR
2024 & 2025 Mavericks
They should fit okay although they’ll throw your speedometer off by about 3% so at 70 on speedo you’re really doing 72.
Mav2023
Mavreal
Northern cali
Mav2024
Hi thank you
also I look on there label it’s said
Vehicle lype
Car
Tire Load Index
105
Ford Maverick TIRES FIT MY MAVERICK? 07785D3D-EFD3-4AF5-BBDC-B608C5E6F85C
Ford Maverick TIRES FIT MY MAVERICK? 1AB1E076-1B0B-4F66-85AC-FA0CF400FA94
Mav2023
Mavreal
Northern cali
Mav2024
I am also planning to used my 4x8 trailer to haul stuff around my house let me know if will be ok thank you
imboden013
West Memphis AR
Load index of 105 means max load of 2039lb per tire. 2039x4 = 8056lb Maverick weighs 3700. So mav plus max cargo of 1500lb is 5200lb then if you tow a trailer tongue weigh which I’d figure between 200-400 lb at most. Figure 6000 lbs robe safe. So load rating okay on a mav. Having said that I’ve never had good luck with Douglas tires.
imboden013
West Memphis AR
I just braved the cold and went to see what the load rating of the stock 225/60r18 Michelins is on my 22 maverick it’s 100H. so 1764lbs the H is speed rating. So those Douglas tires have better load rating than the stock tires
Mav2023
Mavreal
Northern cali
Mav2024
Thank you so much for your answer only reason I got them cause they where $250 for all thank you again I am always lookin for sales lol
imboden013
West Memphis AR
$250 what a steal. Are you a Walmart+ member if so I’d get the lifetime road hazard/balancing If you’re a Walmart+ member you save $10 each tire on that. You get lifetime balance, flat repair and road hazard.
Mav2023
Mavreal
Northern cali
Mav2024
My truck is gettin build next month if I don’t return that tires I will used for summer only I bought some ford focus rs cause I could find fx4 wheels so this ford focus wheels similar I will also will be paint them black to match original fx4 wheels
Ford Maverick TIRES FIT MY MAVERICK? 7C9F7BD6-4279-40B5-B092-D9DCA9A96BD7
imboden013
West Memphis AR
Really i shouldn’t know well thank you
I’m thinking of painting my 18” Mav wheels when I buy new tires. Don’t like the black and chrome look. I’ll probably go with a gunmetal or dark gray color as my mav is cactus gray. I don’t do much off roading and not a lot of snow and ice here so running stock Michelins that still have about 30K miles left on them according to my tire guage measurements. Already have 29k miles on them and guage show about half original tire tread left before replacing them at 3/32nds.
Mav2023
Mavreal
Northern cali
Mav2024
You should check on your local Walmart for clearance tires and ask manager if they can lower they do have many brands on sale sometimes
imboden013
West Memphis AR
I usually shop the Walmart for tires when it comes time. I bought a set of Goodyear 255/50 r20 for my sons explorer about 3 months ago and used my Walmart + membership and saved a $120 dollars. Got them mounted, lifetime balance with road hazard tax and all was $660
Mav2023
Mavreal
Northern cali
Mav2024
Awesome deal
Where should I buy tmps do they sell them at Walmart
imboden013
West Memphis AR
Awesome deal
Don’t know about that never had to buy any. Those you might want to pickup at parts store or ford as they have to be programmed to your vehicle.
Doesn't focus rims fit 12.5 studs and maverick have 14 studs?? Not to mention a larger center size than focus??
