- First Name
- R
- Sep 1, 2023
- California
- 2024 Maverick XL 2.0 AWD 4K CP360
- Engine
- 2.0L EcoBoost
When you have your access panel removed, put your key in and lock and unlock the tailgate. There is a plastic “ring” that will move. I Had to make modifications to the clamp that hooks to the plastic”ring” that the lock actuator moves and hooked it to the right side of that. I had to use my dremel to widen the opening and then I drilled through one of the holes that is supposed to clamp to the rod and just pushed the rod through and bent it in the right spot.@XLAZNDrvr or @RichardCranium
Could you explain how or what the Amazon purchased actuator rod attaches to on the original XL tailgate lock mechanism inside the tailgate?
