Sway Bar for 2024 Lariat (FWD) Hybrid
TimeOutside
Andrew
Hollister, MO
Maverick Lariat
Would this sway bar work for my 2024 Lariat (FWD) Hybrid, or is there another that would be better?
Matso
2011 Mustang GT Premium
Yikes! Do you really want to trust what you're towing with a $50 sway bar? The weld on that receiver just doesn't look up to the job in my opinion. I mean the weld itself looks okay, there just isn't very much of it. I would keep looking.
bluesteel
Jerry
Bergland, MI (U.P.)
2022 Maverick Lariat
A sway bar like this is a very simple device. Many, if not most, of them, including "name brands," are somewhere in the neighborhood of $50.
I have a very similar Reese, and it works great for my 2300 lb. travel trailer. I do not use a WDH with it.
I would add for the OP, however, that I don't think I'd be towing anything large enough to require a sway bar if using the 2K lb. limit hybrid.
RideSolo
Cory
North Central Ohio
'24 Lariat Hybrid, Shadow Black/'20 Escape Titanium Hybrid/'75 BMW R90/6
I'd get that or something similar in a heartbeat. I've done a fair amount of trailer towing and anything you can add for safety is good. Correct, a WDH shouldn't be needed for anything you can safely tow w/ a hybrid, but utility trailers can be deceptively touchy to load and tongue weight. I nearly lost a trailer and two motorcycles due to having too little tongue weight and sway bar like that would have prevented it.
TimeOutside
Andrew
Hollister, MO
Maverick Lariat
...I would keep looking.
...I would add for the OP, however, that I don't think I'd be towing anything large enough to require a sway bar if using the 2K lb. limit hybrid.
I ordered a Curt.
I have a small camper. The designers put the freshwater tank behind the axle. 😞 I travel with it empty, but if I'm boondocking then I'll partially fill my tank as close as I can to my destination. This makes my tongue weight too light, so I'll move stuff from the bed to the front of the camper - including some water jugs needed to top off my tank. With all this I'm a bit overweight and only have about 10% tongue weight. Even though I'm going slow and not going far, I'd rather have that extra safety margin a sway bar provides.
Thank you all for the feedback.
RideSolo
Cory
North Central Ohio
I ordered a Curt.
That episode w/ the motorcycles and trailer, I was way out west somewhere in the middle of nowhere driving a 4cyl S-10. Started down a hill on an Interstate and saw in the mirror that the trailer had started whipping back and forth. At one point I KNEW it was almost gone, somehow knew enough not to step in the brake, and put the gas pedal to the floor. That poor ol' S-10 was doing the best it could and I think that it started to settle down at about 75-80 mph... foot to the floor, downhill for close to a half mile! The next exit had a Lowe's or Home Depot and I bought a bag of sand and a couple of bungee cords; strapped that bag of sand to the trailer tongue and had no more problems all the way to Ohio. There's a good chance that an anti-sway would have prevented it and it's my fault for not having enough tongue weight. In WA my brother and I had switched from 8" wheels to 13" and the trailer towed better but we didn't realize that difference changed the balance on the thing.
bluesteel
Jerry
Bergland, MI (U.P.)
Proper loading of the trailer is important, but a sway bar does give you more room for error and optimizes the journey even when properly loaded (especially in strong winds).
The Real Maverick
Jack
I really like, and really trust 15% weight on the ball. 10% is the MINIMUM. I have never had any sway issues with 15% on the ball. Been doing this for 20 years with a handful of different equipment.
1500 lb to 7500 lb. Trailers.
No WDH or sway bars needed.
15% on the ball. And relatively low center of gravity in the trailers. I usually don't tow equipment with water.
So "sloshing" water may be a key difference. Consider that. But also don't put less than 10% on the ball. Put more.
