Strange HVB behavior
Ranko Kohime
Ranko
2025 Maverick XLT
2025 XLT Hybrid, FWD. I run a ScanGauge, and so I have access to the "HV State of Charge" readout from the computer.
I know all about how Li-* batteries work, and that computed SoC is only a guess, so let's get past that part.
In my Prius, (a 2017 Two-Eco with the Li-Ion pack), whatever SoC I shutdown with was what I got on startup, consistently. (I drive extensively, so greater than 1 day without driving was practically unknown to this vehicle, or my Maverick)
In my Maverick, I have observed, and tracked by conciously recording the shutdown number, a RISE in the SoC, as much as 10-15%. I am sleeping in the back seat many nights, and I typically get woken by the engine if it comes on, so it is unlikely that it is recharging the battery that way.
I have not had the problems with the 12V that others seem to, I have fuse 11 pulled, and I never connected to the Ford app, so I don't know if I'm am missing on sleep mode notifications, but my fob has worked consistently so far, excepting one event in heavy rain where the door handle would not respond. At night though, I can say with certainty that the main contactor is closing. It has a distinctive sound to my ears, that is very different from the multitude of relays clacking. I had assumed it was powering the 12V circuit for some garbage emissions reason or another, but now I am uncertain.
All this to say, I am very much unsure of my hypothesis here, but I wonder if the inverter is operating backwards, by design, or by accident, on some occasions during vehicle off time, charging the HVB from the 12V. This could be on top of any other issues, such as @Mavster Mechanic mentioned in his thread, that the 12V only charges under certain conditions when in Ready mode.
Thoughts?
Also, Ford, release the damn source code to your expensive toys. It makes it hell for us owners that we're kept in the dark about what's going in the hardware that WE OWN, and no I don't care how embarrassing the developer's comments are. #Stallman
Chops
Lobo
As a footnote, the OP has driven over 100,000 miles his first year. My money is on Ranko to be the first forum hybrid owner to hit 200,000. Go Ranko!!
Also 99.9% chance he did NOT get recall 26S36:)
There is a misunderstanding of what Mavster said for one thing.
Not correct that it ONLY charges the 12VB when doing the things listed.
Correct that it only keeps charging above 92 or 85% SOC (AGM or SLA) when you do those things.
Just as there is barely a bit of usage to the HVB to charge the 12VB - you'd drain the 12VB attempting to charge a tidbit of the HVB.
Grief - 12VB will drain just leaving it in Accessory only mode with radio going, lights on, ect.
Truck will turn it's self off in short order.
It's why if the HVB drops to 30% and you are in neutral mode, or key to On not started, it'll stop charging the 12VB and now the 12V system is powered by the 12VB.
As to what initiated this thinking - yes correct that ANY SOC% while a battery is being charged or discharged is a totally calculated value - known size, amps in and out, tracks it.
That can be inaccurate while it's going. Better for lithium.
True up over night. Temps make a difference. Yours goes up. It appears.
Even more so with 12VB SOC%.
Especially on pre-25MY hybrid where the battery size is not stated in BMS specs, but a learn process.
And ya if it's shutdown - it ain't turning the ICE to recharge the HVB.
Sure you turned it off? May be pretty zonked in back seat sometimes!
Mavster Mechanic
Hybrid
My HV batt goes UP 2% to 4% on a regular basis while parked.
Normal. It's a calc. A guess.
Not really "charging up".
Kinda like zeroing in.
Like a poll worker who got 10 responses during the day. Then got 100 responses at night, he can refine his prediction after having more data.
EV's do this too.
You can only know with 100% certainty two things:
0% charged
100% charged
Every point in the middle is a guess.
Always.
Chops
Lobo
Probably only a small group of Ford Engineers/Programmers understand how the calculation is estimated/guessed.
Unless AI does the calculation. Then nobody knows and it is anybody’s guess.
Ranko Kohime
Ranko
2025 Maverick XLT
I'd expect the wheels to have fallen off before the recall if I had that problem.
Leon Hogan
Leon
north central Texas
2026 xlt hybrid
being a E-bike rider also, I know that the lithium battery voltage/percentage does come back up some after loads have been removed and it rest for a couple hours as the voltage difference across the series cells balances out.
Just had 2 trips where I paid attention to see my change.
One was for 5 hrs - stopped in lower 60's, started above 70 - because I got the huge EV mode opportunity up to 20% power.
Did a little drag racing. very little.
Other was just from upper 30's to lower 40's.
Been hot here, likely related with cooling down after a wait.
Ranko Kohime
Ranko
2025 Maverick XLT
All right, so here is a strange thing that just happened. I stopped in a parking lot, with 48% in the battery, shut off, found the place closed, returned in two minutes, and on startup it was below 30%, triggering a recharge cycle that lasted until I drove to a nearby store where in I parked just as it was shutting off at 42%. Also found that place closed, so came back after two minutes, and start up only to have 64% charge.
Lithium batteries simply do not work that way, so Ford’s battery management system is just total garbage. 😉
Mavster Mechanic
Hybrid
Maybe your OBDII reader is complete garbage.
I have never ever seen that.
And I have watched hundreds of cycles. I have my display permanently plugged in and running every drive cycle.
Ranko Kohime
Ranko
2025 Maverick XLT
I’m using a ScanGauge 3, so I dunno. 🤷
My working theory now is Ford screwed something up in the programming for the ‘25+
Mavster Mechanic
Hybrid
Look for patterns. Not one of's.
Does your SOC jump around wildly all of the time? Or just once or twice?
Example: once I saw water temperature of 419°F. Pretty sure my Maverick isn't steam powered. 😜
With all the bits and bytes flying around on a serial bus at figuratively supersonic speeds... packets of data get corrupted here and there.
As long as the packets going to airbag deployment never get corrupted, we'll be fine. The data corrects itself almost instantly.
