- First Name
- Levi
- Nov 16, 2023
- Spring Lake Michigan
- 23 F150-2016 RS/ 22 GT500/ rx8 x2/ 95 mustang GT/ 17 edge.
- Engine
- 2.0L EcoBoost
So went a few weeks back and went better than I expected. But I went back today and realized some issues. First even with all the Nannie’s turned off my stability control kills it. I can be moving right up a very steep hill which our driveline is shockingly good at. Then you hear the brakes being applied and flashing dash stability lights. Truck will slow to a crawl then take off again. Most times leaving you stuck.
So after getting a bit frustrated and deciding to just throttle on. The truck finally turned off the awd. Now when that happened the truck just took off back up the hills spinning only the fronts. So clearly my stability control is over sensitive and using my brakes constantly. This is an xl so no sand mode.
I think I need forscan and just disable stability. When the advanced track disabled once while side hilling no modes were available but the truck just went everywhere with zero troubles.
Now keep in mind this is kinda rough treatment and I know. I was treating it as a toy and I know I was abusing it. I’m ok with that.
