Rolling noise on deceleration
Mavelock
Simon
Ford maverick 22 xlt tow package
Maverick 22 2.0l tow package
anyone has experienced a constant rolling sound at 37mph with an increase in sound that peaks at 12mph and diminishes until stopped, front left/center, brake or not the noise stays there, less present when accelerating, the dealer rotated the tires, changed my rear brakes, replaced a transmission support, replaced a wheel table, replaced a driving, balanced the tires, did a test with other tires, the noise does not appear once mounted on the elevator, I'm starting geting nerve, the dealer always trying to blame me because they can't find where it come from
Carlitos_92
That is a very good attempt at a thorough description, but there are so many things it could be...
I'm impressed the dealer tried so many things already, but for anyone around here to make an educated guess, it's going to take a video or audio recording, or something.
EngineeredDetails
Andy
Vance, AL
2004 F150, 2016 Fusion, 2017 Explorer
You could have a wheel bearing going out if they haven't checked that. A bad one can be very noisy when slowing down and sound alright while accelerating. A good way to tell is by seeing if the sound goes away while turning at those speeds. If you turn left and it goes away left side bearing is bad. Turn right and it goes away right side bearing is bad. Noise may not go completely away but significantly better as you transfer the weight of the vehicle to one side while unloading the weight from the other
Find a new dealership. There are not that many good techs around, and either this dealership doesn't have one or hasn't assigned him to work on your truck yet. Either way, I don't think you're going to get resolution from this dealership so it's (past) time to look elsewhere.
If by some chance you literally do not have another dealership within an hour, it's more difficult, but personally I'd ask locals for a good independent shop and take it there.
Milwrdfan
Scott
Iowa
25 Lariat Hybrid
Did they check the CV joints? I believe those were trouble spots on many Mavericks, so if they haven't checked that, have them look at those to see if it's the source of the noise.
Mavelock
Simon
Got some news, since to be my PTU(transfer case) 1.5liter oil missing, the bearing are noisy as hell, the parts is not available for the moment, maybe 2 months for get the parts, during this time I run it until PTU destruction or when I found a perpetual neutral speed i guess
