Replacing/covering XL cloth upper door panel areas...
bwiese
San Jose CA
2018 RAM 1500 quad cab V6; 2022 MavXL hybrid
Esp for drivers' door, the upper cloth near-handle area can get dusty/dirty. Really that upper area should have been non-cloth plastic/vinyl, etc.
Are there any aftermarket replacements for this upper cloth area (I think the lower areas are for speaker and I can leave that alone). Sure, it looks good in design photos but that was one thing I think not well thought-out. Or, are there any XLT/Lariat/etc. substitutable non-cloth parts there?
Plan B, otherwise, is just to cover it with clear plastic carpet protector sheet.
San Jose CA
Can you post a picture of the area you are referencing? Pictures help some people to visualize.
Thank You
bwiese
San Jose CA
Thank You
Glen,
This... perhaps it's termed 'cloth rear armrest' or 'bolster'
See picture below...
-Bill
Ford Maverick Replacing/covering XL cloth upper door panel areas... IMG_20240707_170329798
Bill,
Thank you for the picture
I see now.
I had no idea what you were talking about. I did not think about the armrest being cloth.
Mine appears to be active-x
a.k.a. pleather. Hmmm I wonder what an auto upholstery shop would charge to recover those? Or what a set of xlts would run through Ford or auto salvage??
Good luck
GB
Ford Maverick Replacing/covering XL cloth upper door panel areas... IMG20240707175127
Carlitos_92
https://parts.lakelandford.com/a/Fo...04734/Front-door-Interior-trim/MM22625.html#5
Part #5 in this image is probably what you want. The XLT version is vinyl-esque. I think the Lariats are the same for that part. It's a $70 upgrade (per side), but I had no idea it was cloth in the XLs.
Not sure if you can replace it without pulling the whole door card, but there is probably a stereo upgrade thread around here with some good pics of the inside of the door.
MAVRICK
Any
2024 XL
Would you happen to know if that is mounted from behind the door panel OR can it just be popped off from the exposed front of the door panel using trim removal tools ... [pic below]
Ford Maverick Replacing/covering XL cloth upper door panel areas... 1720475556147-c5
Carlitos_92
No, I do not know, which is what I tried to say in my post.
I suggested looking through a stereo upgrade thread, because many folks have documented adding sound deadening or other tweaks while they worked on the door speakers. The post above yours also links to a thread about the door assembly which might be handy.
MAVRICK
Any
2024 XL
Thanks. I watched those videos ... didn't help.
