Remote start on 2023 Maverick XL/XLT-- successfully installed aftermarket solution
All4spl
All4spl
Longwood, FL
2023 Ford Maverick XLT
Ford pass app works great though.
I had ford pass on my Edge ST, and yes it does work, when I am walking out of the house in the morning sure ford pass is fine. However any other time, at a hardware store, gas station or etc, the remote clicks to start are MUCH more convenient.
Decayed
yes
a car
Yeah there is a convenience factor. I'm biased because some knucklehead wired in an aftermarket remote start in the used 05 explorer we own and it caused no end of trouble.
All4spl
All4spl
Longwood, FL
I understand your concern, however technology has come a long way and this does not involve any wire cutting. This simply plugs into the ODBII harness and then you program the module and done. It's not like back in the day when you had to splice into the starting wiring and etc.
Decayed
yes
a car
That's good because you should see the friggin rat's nets of wires under my explorer's dash.
MM Mav
Amy
Great Lakes Region
Thanks for the tip and link for the remote starter.
I see you have an Ecoboost. Do you know if it will work in the Hybrid?
Per Start-X's website, this kit will work with hybrid standard key and push button start.
OB1e
Massachusetts
CG LUX XLT
Gullzway
OK
1968 Ford Mustang Fastback
gwalton1234
Geoff
St. Louis
2007 Saturn Aura
Gullzway
OK
How do you like the alarm system? I am thinking of adding it.
Love it. You can adjust sensitivity to your preference. Gives a chirp if you lightly hit/tap the truck or tires. Alarm goes off with any harder force and I get a notice on my Ford Pass app.
NoCoolNameDave
Earth
2023 Maverick Tremor
Does it come with the remote start key fobs and if not how do you start it?
CACTI_HYBRID
Rick
Meridian, ID
2022 Ford Maverick XL Hybrid
What am I not understanding here? What does this do that simply using the FordPass all via your phone does not?
Gullzway
OK
It does Not come with a fob. My Maverick already had remote start, but from what I've read the stock fob will work on non remote start vehicles.
Functionality:
Stock fobs will work! If you only install the pps module you will get keyfob remote start (not sure on distance)
Press LOCK, UNLOCK, LOCK
