Question about soft tonneau covers
RayRays maverick
Claude
Virginia
2014 Ford F-150 Stx single cab 5.0 V-8 coyote
I’m having a tri fold soft cover installed on my xlt 2023 maverick the bed does not have a track slider along the side.
Will that be a problem for installing the tonnage cover?
Thanks in advance.
fossil
ernie
ohio
Ford Maverick Question about soft tonneau covers nope-22
Suzukiridr14
Frank
Sarasota Florida
Thanks in advance.
You don't need to worry about needing a slider rail to install the trifold cover. The cover connects to the foward end of the bed by the rear window with plastic clamps that grip the underside of the rail. The aft clamps also grip the bed the same way, but are spring loaded for quick access to uncover the bed, and fold up. Not sure if you can install it with a drop in liner.
MaverickEVwouldBeNice
Earth - Northern Hemisphere - North America - USA
2023 Mav Hyb/lux
Thanks in advance.
I installed the TipTop cover from Amazon last Friday morning. It was a 10 minute install, despite temps being in the low 20s. Then I went on a 900 mile round trip to Canada, had zero issues, just checked on all connections during one stop. I don't drive all that fast, but occasionally hit 80 wihle passing.
I don't have a track slider or slider rails, not sure if I understand where that would be installed. Are you referring to the cargo management system option? If that's it, it is not required for after market tonneau covers.
Most installations are similar to the way @Suzukiridr14 described it. In my case, the cover was clamped to the bed on the sides, not right under the window, using 4 T-screws and short metal plates. The clamps near the tailgate use the same type T-screws, but clamp down the bed with quite some force.
JP4AZ
Phoenix
Suzukiridr14
Frank
Sarasota Florida
I didn't mean it clamped to the rail behind the window, (thank you for correcting me) I was referring to the foward section of the cover. it clamps to the side rails like you said.
RayRays maverick
RayRays maverick
Claude
Virginia
Thank you all my questions were answered, what a great forum 😎
2023 Mav Hyb/lux
Man, I read your description and was thinking that I would've preferred to have a way to secure my cover that way. Or at least have one or two extra clamps right against the wall under the rear window.
But I looked at my cover again this afternoon, and I don't think there is a way to add clamps. Would be nice if there was. That would really keep any moisture out.
WJOHNM
New York,LI
Thanks in advance.
I have the Ford tri-fold, I installed in about 20 min on my XLT LUX FX4.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Got the OEM soft cover from Ford dealership, has performed very well since June.
JP4AZ
Phoenix
just put some weather stripping along that edge (close to the bed as possible). No need/reason for clamps below the window. The side rail clamps are more than enough to hold it down.
2023 Mav Hyb/lux
Probably something I will look into next spring. We got 6" of snow Friday night, I'm not going to attempt anything that requires an adhesive to stick to something else.
Winter is coming
jeffj
jeffj
Surprise, AZ
2024 Ford Bronco & 2024 Maverick
Great T Cover
Ford Maverick Question about soft tonneau covers 1maverick
