Question about 2025 lobo exhausts
25loboMA
Jackson
MA
2025 Ford Maverick Lobo Standard
Hello all, I just picked up a low mile 2025 Lobo. My truck was made before they started adding GPF filters to the exhaust. I’m assuming that means that I have the same exhaust as other pre-GPF Mavericks.
Should I be actively avoiding 2025 exhaust kits because they might have something to correlate to the GPF sensor?
https://www.shopmrt.com/2025-Maverick-Lobo-Extreme-Exhaust-MRT-p/92w306-l.htm
thisnis the exhaust i was looking at. Essentially im just worried it wont fit my non GPF exhaust if its made for a 2025 model with the GPF. Does it even matter?
thank you so much!
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
thank you so much!
Save Yourself a bunch of money and just install the Magnaflow Muffler like a guy did on here with the 2025 Maverick with the 2.0 EB!!
Chops
Lobo
thank you so much!
The GPF or lack thereof will not affect the install. The Lobo and aftermarket Lobo exhausts just have a different bend under the torque vectoring RDU.
If you are going to do this install yourself - the hardest part is cutting your pipe right in front of the muffler. After that - easy peasy:)
Chops
Lobo
I wish you told me before I installed my Borla X-Type catback:) Magnaflow was my first choice - but they still do not offer a catback for the 25+ EBs.
In hindsight I just should have had a muffler shop install only a magnaflow muffler. Would have saved myself $500+ with better sound too!
BLUEOVALRACER
Ravenna,Ohio
If My stock muffler starts to look really crappy, I'll probably go to the Magnaflow Muffler!!
Chops
Lobo
You may be waiting a long time:)
The OEM muffler & pipes seemed very robust & well made when I cut mine off.
Made from 400-series stainless steel for longevity against internal corrosion. The exterior surface can develop a harmless surface rust however.
But the Magnaflow, along with the stock resonator patch, has a low rumble that makes the boring EB sound a bit better!
25loboMA
Jackson
MA
Thank you!
25loboMA
Jackson
MA
I’m now considering this. I both thank you , and despise you for making my decision harder. I spend a week narrowing down every exhaust I could find
Jawny
Wess
New Jersey
2022 Ford Maverick Lariat
I put a custom 3" exhaust with a Magnaflow 12259 and it is pretty solid. I ended up putting resonator (vibrant) because it was pretty loud but that is just personal preference.
FERALMAVERICK
Brent
2025 maverick tremor
there is a fair amount of options out there if you want a system , just make sure it says it fits the lobo / tremor the tailpipe is configured differently if i remember correct . you could always have a system done or just change out the muffler .
