Order verification
GAP
Lancaster, PA
Honda Pilot
How can I check that my order was placed correctly and in a timely manner?
Syntax Error
2023 Lariat Hybrid Carbonized Grey
Ask your dealer? At the very least you should have a WBDO build sheet that shows the order code, dealer code, and priority code. You can then use this info to check with Ford chat what the current status of your order is.
If you're asking if your order was properly COVP'd, that's all up to the dealer so you have to ask them that this was done while it was possible. They should have done this if they are actually competent since 2022 to 2023 rollovers got screwed over with not being eligible for the private offer if their dealers were clowns and didn't do a COVP.
Maverickman74
Shane
Maui HI
Just call or "chat" with Ford Chat, its in the support section of Ford.com
gte105u
Katy, TX
Well the placed part is check with Ford chat. The timely manner... Did you put it in with your dealer back in September? If not then timely is whenever the order banks open next.
