Okay, what's the trick with this clip?
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
I'm trying to install a dashcam and i can't figure out how to get the pictured clip to release.
This is above the reading lights, and is where the pigtail adapter is supposed to patch in. In Mangoal's installation video (which was clearly filmed in something OTHER than a Maverick) the clip just seems to pull free with a little wiggle. Mine has what appears to be locking tab, but even when pulled, the clip remains stubbornly attached.
As you can see, I'm starting to damage the clip trying to get it to release. Really rather annoying.
Ford Maverick Okay, what's the trick with this clip? IMG_3905
BK007
BK007
OH
press (push down) on that clear plastic tab to release the lock.
Wahjahbvious
Wahjahbvious
Erf
It seemed like what worked was squeezing the black tab indicated below, but maybe in so doing, I was actually putting pressure on the clear/white bit also.
baccus100176
SC
26 Lariat Hybrid AWD
Had your same frustration installing a pigtail at that connector. Maddening until I pressed that little black tab. The rear lights are almost the same configuration (slide the release tab up and then depressing a secondary tab)
Wahjahbvious
Wahjahbvious
Erf
Posting about it here helped, because I couldn't actually *see* the secondary tab until I took a pic of it.
Presbyopia is a bitch.
Mangoal
Diamond Sponsor
North America
linktr.ee
2024 Maverick XLT
Glad you got it sorted! With the black tab and the clear slide stacked like that, it's easy to miss what's actually holding it. This thread will save the next Maverick owner some frustration.
And yep, our video wasn't shot on a Maverick, fair call. We've passed the feedback along to the team. Shout if anything else gives you trouble during the install.
